[Qgis-developer] Opening composer from Python
Alexander Bruy alexander.bruy at gmail.com
Thu Oct 31 01:30:14 PDT 2013
>From further test I see that crash occurs after setComposition() call
2013/10/31 Alexander Bruy <alexander.bruy at gmail.com>:
> Hi all,
> I need to create composer window with prepared composition from Python.
> There is an createNewComposer() method and seems this is what I need.
> I run simple test from Python console and it works, but when I tried to use
> same code from plugin QGIS crashes. Here is code for console:
> canvas = iface.mapCanvas()
> renderer = canvas.mapRenderer()
> composition = QgsComposition(renderer)
> composition.setPlotStyle(QgsComposition.Print)
> composition.setPrintResolution(300)
> composition.setPrintAsRaster(True)
> map = QgsComposerMap(composition, 5, 5, 200, 200)
> map.setNewExtent(canvas.currentLayer().extent())
> composition.addItem(map)
> c = iface.createNewComposer()
> c.setComposition(composition)
> Any ideas what can be wrong? Maybe I miss something obvious?
> Alexander Bruy
Alexander Bruy
