[Qgis-developer] Changing plugin maintainer in repository
Chris Crook
ccrook at linz.govt.nz
Tue Sep 17 02:00:54 PDT 2013
Hi
Just wondering what the procedure is to change the maintainer of a plugin in the QGIS plugin repository? Any suggestions...
Thanks
Chris
This message contains information, which is confidential and may be subject to legal privilege. If you are not the intended recipient, you must not peruse, use, disseminate, distribute or copy this message. If you have received this message in error, please notify us immediately (Phone 0800 665 463 or info at linz.govt.nz) and destroy the original message. LINZ accepts no responsibility for changes to this email, or for any attachments, after its transmission from LINZ. Thank You.
