[Qgis-developer] Changing plugin maintainer in repository
Alessandro Pasotti
apasotti at gmail.com
Tue Sep 17 02:17:20 PDT 2013
it can be done only by an admin user through the control panel.
2013/9/17 Chris Crook <ccrook at linz.govt.nz>
> Hi
> Just wondering what the procedure is to change the maintainer of a plugin
> in the QGIS plugin repository? Any suggestions...
> Thanks
> Chris
> This message contains information, which is confidential and may be
> subject to legal privilege. If you are not the intended recipient, you must
> not peruse, use, disseminate, distribute or copy this message. If you have
> received this message in error, please notify us immediately (Phone 0800
> 665 463 or info at linz.govt.nz) and destroy the original message. LINZ
> accepts no responsibility for changes to this email, or for any
> attachments, after its transmission from LINZ. Thank You.
> Qgis-developer mailing list
Alessandro Pasotti
w3: www.itopen.it
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20130917/b105f98f/attachment-0001.html>
