[Qgis-developer] Format conversion QGIS 2.0
Giovanni Manghi giovanni.manghi at faunalia.pt
Tue Sep 17 02:56:11 PDT 2013
>> I can confirm this bug, forwarding to the developer list. Temporary
>> workaround, is to press the pencil button and edit the -of part of
>> the
>> command to the correct format as listed on
>> http://gdal.org/formats_list.html
>> In this case it should say "-of AAIGrid"
> Hi all.
> It looks easy to fix: would it be worth a 2.0.2 release?
there is a pull request with the patch that fixes this
https://github.com/qgis/QGIS/pull/786
cheers
