[Qgis-developer] Processing report: first issues
Noli Sicad
nsicad at gmail.com
Sat Sep 21 05:36:55 PDT 2013
Hi Victor,
The OTB and Grass plugins are not working in Windows 7 and Mac OS X.
Previously in QGIS 1.9.0, the Unsupervised KMeans image classification
in OTB, was working, however, GRASS is not working as well. I am
trying to use raster.reclass in GRASS.
In OTB, the problem is output.tiff and in the GRASS the input raster
is not found.
How do we fix these problem.
Anybody using OTB and GRASS in Linux (Ubuntu)? Does OTB and GRASS
works in QGIS 2.0.1?
Thanks.
Regards, Noli
On 9/21/13, Victor Olaya <volayaf at gmail.com> wrote:
> Is that 2.0.1 that you were using in those win machines. The
> standalone installer was working perfectly here in 10 computer with
> win 7... Hopefully we will be able to prepare a new version of
> Processing, to release it independently quite soon. I hope the problem
> i there and easy to fix, but it might be in the SAGA installation, so
> it might require a new QGIS version :-(
> 2013/9/20 matteo <matteo.ghetta at gmail.com>:
>>>> * all Ubuntu machines could not run saga, because they have 2.0.7
>>> you need to add a PPA with saga 2.10.
>> mmm.. I work with Ubuntu (13.04), but if I add the repository for the 2.1
>> version of saga, there is a conflict between gdal libraries.
>> So it seems that it's not possible to install saga and the new qgis
>> version
>> at the same time (without compiling)
>> Matteo
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
