[Qgis-developer] Fwd: Q-Rap plugin
Magdaleen Ballot
Magdaleen.Ballot at up.ac.za
Fri Sep 20 02:28:33 PDT 2013
I am currently th only active developer on Q-Rap, a Radio Planning plugin for QGis (source code at http://sourceforge.net/projects/qrap/). I recently updated it to work with Qgis version 2 (the upgrade on the Ubuntu repositories catch me a bit surprised as the Web-site still only talks about version 1.80).
None the less, my main problem is that I am having trouble to have Q-Rap "stick":
It loads successfully, however when I close Q-Gis down and open it up again the tool bar is not there.<BR>Q-Rap is still selected, but it would seem like the constructor and initGui is not run again when I open up QGis. so now I have to un select the Q-Rap plugin and selects it again ... and then it loads.
I had another look at the plugin-template and some other plugin implementations in the source code, but I <BR>really don't get it. Q-Rap creates its own new ToolBar on the QGis-interface.
(I had this problem in 1.8 as well ... in version 1.7 it worked fine)
Is this a bug in QGis or am I blind to what I am doing wrong?
On another topic;
On the Q-Rap mailing list I got the following message for Giovanni:
">> http://www.qgis.org/api/INSTALL.html ( http://www.qgis.org/api/INSTALL.html )
> ( http://www.qgis.org/api/INSTALL.html ) I doubt anyway that you will be able to make qrap works with the
> latest QGIS source code as it does not seem to have been updated recently.
> QGIS C++ plugins should be added upstream and maintained updated
> there, otherwise they are going the become quickly obsolete and of
> course stop to work
>> cheers>> -- Giovanni --"
I also got a similar suggestion from Paolo Cavallini of the LinkedIn QuantumGIS group that I should be doing the same. The fact of the matter is that I would really like to do just that.
How does one go about it? Is there any-one that can help me with this? As I am currently the only active developer and should actually be spending my time on research and teaching.
(I have not yet try to compile it under windows.)
Kind Regards
Magdaleen Ballot.
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20130920/4fcf2321/attachment.html>
