[Qgis-developer] QGIS 2.0 Win standalone busted
Giovanni Manghi giovanni.manghi at faunalia.pt
Sat Sep 21 11:51:08 PDT 2013
> That is a layer that is used to run a test, to check that GRASS and
> SAGA are installed. Maybe when the data is in a path with blank spaces
> (as this case, since that data is in the Processing folder), GRASS
> doesn't like it?
I tested again installing qgis standalone 64 bit in c:\qgis, the path
to data does not have spaces and the result is the same. I tested
raster and vector modules, and the very same operations with the same
outputs o work in qgis 2.0 installed with osgeo4w (32 bit).
