[Qgis-developer] QGIS 2.0 Win standalone busted
    Giovanni Manghi
    giovanni.manghi at faunalia.pt
    Sat Sep 21 12:01:07 PDT 2013
On Sat, Sep 21, 2013 at 5:06 PM, Victor Olaya <volayaf at gmail.com> wrote:
> I had a closer look at the problem with GRASS and the 64 bit installer
> (which I guess ight be the same in other installers that do not work
> correctly). It passes the test fine (the test that uses the points.shp
> file), so it lets you get to the dialog. Vector operations (like the
> test one) work fine, but rasters do not. Processing calls GRASS
> correctly and detects the path without problems, but then GRASS
> complains that "It was not possible to load GDAL library".
> Giovanni, your problems are with raster layers as well, i guess, since
> you can open the dialogs (meaning that vector modules run fine)
> Is this a packaging problem? I have no idea about how to fix this...
> Any GRASS (or packaging) expert can tell us why GRASS cannot load GDAL
I confirm that with rasters the message
shows in the log.
On the other hand vector operations do not always run ok. For example
I can't get a dissolve done, and the same operation with the same
input is ok in qgis installed with osgeo4w.
Here is the log
Algorithm v.dissolve - Dissolves boundaries between adjacent areas
sharing a common category number or attribute. started
g.proj -c proj4="+proj=tmerc +lat_0=39.66825833333333
+lon_0=-8.133108333333334 +k=1 +x_0=0 +y_0=0 +ellps=GRS80
+towgs84=0,0,0,0,0,0,0 +units=m +no_defs"
v.in.ogr min_area=0.0001 snap=-1
dsn="C:\Users\giovanni\Desktop\mestrado" layer=lynxrabbit_fav_10km
output=tmp13797900260521 --overwrite -o
g.region n=448790.113802 s=-406706.831024 e=942489.861849 w=-121397.364409 res=1
v.dissolve input=tmp13797900260521 column=dissolve
output=outputcd3563ec198c4675b82ed436eef6acf2 --overwrite
v.out.ogr -e input=outputcd3563ec198c4675b82ed436eef6acf2
dsn="C:\Users\giovanni\AppData\Local\Temp\processing\f7500099774b47d897aaa2de43ac86b3"
format=ESRI_Shapefile olayer=output type=auto
C:\qgis\bin>set HOME=C:\Users\giovanni
C:\qgis\bin>set GISRC=C:\Users\giovanni\.qgis2\\processing\processing.gisrc
C:\qgis\bin>set GRASS_SH=C:/qgis/apps\msys\bin\sh.exe
C:\qgis\bin>set
PATH=C:/qgis/apps\msys\bin;C:/qgis/apps\msys\lib;C:/qgis/apps/grass/GRASS-~1.3/bin;C:/qgis/apps/grass/GRASS-~1.3/scripts;C:/qgis/apps/qgis/./grass/scripts/;C:/qgis/bin;C:\qgis\apps\grass\grass-6.4.3\bin;C:\qgis\apps\msys\bin;C:\qgis\apps\Python27\Scripts;C:\qgis\bin;C:\Program
Files (x86)\Intel\iCLS Client\;C:\Program Files\Intel\iCLS
Client\;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Program
Files\Intel\WiFi\bin\;C:\Program Files\Common
Files\Intel\WirelessCommon\;C:\Program Files\ThinkPad\Bluetooth
Software\;C:\Program Files\ThinkPad\Bluetooth
Software\syswow64;;C:\Program Files\Intel\Intel(R) Management Engine
Components\DAL;C:\Program Files\Intel\Intel(R) Management Engine
Components\IPT;C:\Program Files (x86)\Intel\Intel(R) Management Engine
Components\DAL;C:\Program Files (x86)\Intel\Intel(R) Management Engine
Components\IPT;C:\Program Files (x86)\Lenovo\Access
Connections\;C:\Program Files\Intel\WiFi\bin\;C:\Program Files\Common
Files\Intel\WirelessCommon\;C:\qgis\apps\msys\bin;C:\qgis\apps\qgis\bin;C:\qgis\apps\grass\grass-6.4.3\lib
C:\qgis\bin>set WINGISBASE=C:/qgis/apps\grass\grass-6.4.3
C:\qgis\bin>set GISBASE=C:/qgis/apps\grass\grass-6.4.3
C:\qgis\bin>set GRASS_PROJSHARE=C:/qgis/apps\grass\grass-6.4.3\share\proj
C:\qgis\bin>set GRASS_MESSAGE_FORMAT=gui
C:\qgis\bin>if "" == "" set
PATH=C:/qgis/apps\grass\grass-6.4.3\bin;C:/qgis/apps\grass\grass-6.4.3\lib;C:/qgis/apps\msys\bin;C:/qgis/apps\msys\lib;C:/qgis/apps/grass/GRASS-~1.3/bin;C:/qgis/apps/grass/GRASS-~1.3/scripts;C:/qgis/apps/qgis/./grass/scripts/;C:/qgis/bin;C:\qgis\apps\grass\grass-6.4.3\bin;C:\qgis\apps\msys\bin;C:\qgis\apps\Python27\Scripts;C:\qgis\bin;C:\Program
C:\qgis\bin>if not "" == "" set
PATH=C:/qgis/apps\grass\grass-6.4.3\bin;C:/qgis/apps\grass\grass-6.4.3\lib;;C:/qgis/apps\grass\grass-6.4.3\bin;C:/qgis/apps\grass\grass-6.4.3\lib;C:/qgis/apps\msys\bin;C:/qgis/apps\msys\lib;C:/qgis/apps/grass/GRASS-~1.3/bin;C:/qgis/apps/grass/GRASS-~1.3/scripts;C:/qgis/apps/qgis/./grass/scripts/;C:/qgis/bin;C:\qgis\apps\grass\grass-6.4.3\bin;C:\qgis\apps\msys\bin;C:\qgis\apps\Python27\Scripts;C:\qgis\bin;C:\Program
C:\qgis\bin>set GRASS_VERSION=6.4.0
C:\qgis\bin>if not "" == "" goto langset
C:\qgis\bin>FOR /F "usebackq delims==" %i IN
(`"C:/qgis/apps\grass\grass-6.4.3\etc\winlocale"`) DO @set LANG=%i
C:\qgis\bin>set
PATHEXT=.COM;.EXE;.BAT;.CMD;.VBS;.VBE;.JS;.JSE;.WSF;.WSH;.MSC;.PY
C:\qgis\bin>set
PYTHONPATH=C:/qgis/apps/grass/GRASS-~1.3/etc/python;;C:/qgis/apps\grass\grass-6.4.3\etc\python;C:/qgis/apps\grass\grass-6.4.3\etc\wxpython\n
C:\qgis\bin>g.gisenv.exe set="MAPSET=PERMANENT"
C:\qgis\bin>g.gisenv.exe set="LOCATION=temp_location"
C:\qgis\bin>g.gisenv.exe set="LOCATION_NAME=temp_location"
set="GISDBASE=C:\Users\giovanni\AppData\Local\Temp\processing\grassdata"
C:\qgis\bin>g.gisenv.exe set="GRASS_GUI=text"
C:\qgis\bin>g.proj -c proj4="+proj=tmerc +lat_0=39.66825833333333
GRASS_INFO_MESSAGE(6544,1): Default region was updated to the new
projection, but if you have multiple mapsets `g.region -d` should be
run in each to update the region from the default
GRASS_INFO_END(6544,1)
GRASS_INFO_MESSAGE(6544,2): Projection information updated
GRASS_INFO_END(6544,2)
C:\qgis\bin>v.in.ogr min_area=0.0001 snap=-1
GRASS_INFO_WARNING(6880,1): Datum not recognised by GRASS and no
parameters found
GRASS_INFO_END(6880,1)
GRASS_INFO_MESSAGE(6880,2): Over-riding projection check
GRASS_INFO_END(6880,2)
GRASS_INFO_MESSAGE(6880,3): Layer: lynxrabbit_fav_10km
GRASS_INFO_END(6880,3)
GRASS_INFO_MESSAGE(6880,4): Counting polygons for 4840 features...
GRASS_INFO_END(6880,4)
GRASS_INFO_MESSAGE(6880,5): Importing map 4840 features...
GRASS_INFO_END(6880,5)
GRASS_INFO_MESSAGE(6880,6):
GRASS_INFO_END(6880,6)
GRASS_INFO_MESSAGE(6880,7): Building topology for vector map ...
GRASS_INFO_END(6880,7)
GRASS_INFO_MESSAGE(6880,8): Registering primitives...
GRASS_INFO_END(6880,8)
1000 2000 3000 4000 5000
6000 7000 8000 9000
GRASS_INFO_MESSAGE(6880,9): 9724 primitives registered
GRASS_INFO_END(6880,9)
GRASS_INFO_MESSAGE(6880,10): 29152 vertices registered
GRASS_INFO_END(6880,10)
GRASS_INFO_MESSAGE(6880,11): Number of nodes: 5007
GRASS_INFO_END(6880,11)
GRASS_INFO_MESSAGE(6880,12): Number of primitives: 9724
GRASS_INFO_END(6880,12)
GRASS_INFO_MESSAGE(6880,13): Number of points: 0
GRASS_INFO_END(6880,13)
GRASS_INFO_MESSAGE(6880,14): Number of lines: 0
GRASS_INFO_END(6880,14)
GRASS_INFO_MESSAGE(6880,15): Number of boundaries: 9724
GRASS_INFO_END(6880,15)
GRASS_INFO_MESSAGE(6880,16): Number of centroids: 0
GRASS_INFO_END(6880,16)
GRASS_INFO_MESSAGE(6880,17): Number of areas: -
GRASS_INFO_END(6880,17)
GRASS_INFO_MESSAGE(6880,18): Number of isles: -
GRASS_INFO_END(6880,18)
GRASS_INFO_MESSAGE(6880,19):
GRASS_INFO_END(6880,19)
GRASS_INFO_WARNING(6880,20): Cleaning polygons, result is not guaranteed!
GRASS_INFO_END(6880,20)
GRASS_INFO_MESSAGE(6880,21):
GRASS_INFO_END(6880,21)
GRASS_INFO_MESSAGE(6880,22): Break polygons:
GRASS_INFO_END(6880,22)
GRASS_INFO_MESSAGE(6880,23):
GRASS_INFO_END(6880,23)
GRASS_INFO_MESSAGE(6880,24): Remove duplicates:
GRASS_INFO_END(6880,24)
GRASS_INFO_MESSAGE(6880,25):
GRASS_INFO_END(6880,25)
GRASS_INFO_MESSAGE(6880,26): Break boundaries:
GRASS_INFO_END(6880,26)
GRASS_INFO_MESSAGE(6880,27):
GRASS_INFO_END(6880,27)
GRASS_INFO_MESSAGE(6880,28): Remove duplicates:
GRASS_INFO_END(6880,28)
GRASS_INFO_MESSAGE(6880,29):
GRASS_INFO_END(6880,29)
GRASS_INFO_MESSAGE(6880,30): Clean boundaries at nodes:
GRASS_INFO_END(6880,30)
GRASS_INFO_MESSAGE(6880,31):
GRASS_INFO_END(6880,31)
GRASS_INFO_MESSAGE(6880,32): Merge boundaries:
GRASS_INFO_END(6880,32)
GRASS_INFO_MESSAGE(6880,33):
GRASS_INFO_END(6880,33)
GRASS_INFO_MESSAGE(6880,34): Change dangles to lines:
GRASS_INFO_END(6880,34)
GRASS_INFO_MESSAGE(6880,35):
GRASS_INFO_END(6880,35)
GRASS_INFO_MESSAGE(6880,36): Remove bridges:
GRASS_INFO_END(6880,36)
GRASS_INFO_MESSAGE(6880,37):
GRASS_INFO_END(6880,37)
GRASS_INFO_MESSAGE(6880,38): Building topology for vector map ...
GRASS_INFO_END(6880,38)
GRASS_INFO_MESSAGE(6880,39): Building areas...
GRASS_INFO_END(6880,39)
GRASS_INFO_MESSAGE(6880,40): 4836 areas built
GRASS_INFO_END(6880,40)
GRASS_INFO_MESSAGE(6880,41): 1 isles built
GRASS_INFO_END(6880,41)
GRASS_INFO_MESSAGE(6880,42): Attaching islands...
GRASS_INFO_END(6880,42)
GRASS_INFO_MESSAGE(6880,43): Number of nodes: 5033
GRASS_INFO_END(6880,43)
GRASS_INFO_MESSAGE(6880,44): Number of primitives: 29089
GRASS_INFO_END(6880,44)
GRASS_INFO_MESSAGE(6880,45): Number of points: 0
GRASS_INFO_END(6880,45)
GRASS_INFO_MESSAGE(6880,46): Number of lines: 0
GRASS_INFO_END(6880,46)
GRASS_INFO_MESSAGE(6880,47): Number of boundaries: 29089
GRASS_INFO_END(6880,47)
GRASS_INFO_MESSAGE(6880,48): Number of centroids: 0
GRASS_INFO_END(6880,48)
GRASS_INFO_MESSAGE(6880,49): Number of areas: 4836
GRASS_INFO_END(6880,49)
GRASS_INFO_MESSAGE(6880,50): Number of isles: 1
GRASS_INFO_END(6880,50)
GRASS_INFO_MESSAGE(6880,51): Number of areas without centroid: 4836
GRASS_INFO_END(6880,51)
GRASS_INFO_MESSAGE(6880,52):
GRASS_INFO_END(6880,52)
GRASS_INFO_MESSAGE(6880,53): Find centroids for layer: lynxrabbit_fav_10km
GRASS_INFO_END(6880,53)
GRASS_INFO_MESSAGE(6880,54):
GRASS_INFO_END(6880,54)
GRASS_INFO_MESSAGE(6880,55): Write centroids:
GRASS_INFO_END(6880,55)
GRASS_INFO_WARNING(6880,56): 4 areas represent more (overlapping)
features, because polygons overlap in input layer(s). Such areas are
linked to more than 1 row in attribute table. The number of features
for those areas is stored as category in layer 2
GRASS_INFO_END(6880,56)
GRASS_INFO_MESSAGE(6880,57):
GRASS_INFO_END(6880,57)
GRASS_INFO_MESSAGE(6880,58): 4840 input polygons
GRASS_INFO_END(6880,58)
GRASS_INFO_MESSAGE(6880,59): Total area: 5.86438E+011 (4836 areas)
GRASS_INFO_END(6880,59)
GRASS_INFO_MESSAGE(6880,60): Overlapping area: 4.8118E+008 (4 areas)
GRASS_INFO_END(6880,60)
GRASS_INFO_MESSAGE(6880,61): Area without category: 0 (0 areas)
GRASS_INFO_END(6880,61)
GRASS_INFO_MESSAGE(6880,62):
GRASS_INFO_END(6880,62)
GRASS_INFO_MESSAGE(6880,63): Building topology for vector map ...
GRASS_INFO_END(6880,63)
GRASS_INFO_MESSAGE(6880,64): Registering primitives...
GRASS_INFO_END(6880,64)
6000 7000 8000 9000 10000
11000 12000 13000 14000
GRASS_INFO_MESSAGE(6880,65): 14627 primitives registered
GRASS_INFO_END(6880,65)
GRASS_INFO_MESSAGE(6880,66): 24555 vertices registered
GRASS_INFO_END(6880,66)
GRASS_INFO_MESSAGE(6880,67): Building areas...
GRASS_INFO_END(6880,67)
GRASS_INFO_MESSAGE(6880,68): 4836 areas built
GRASS_INFO_END(6880,68)
GRASS_INFO_MESSAGE(6880,69): 1 isles built
GRASS_INFO_END(6880,69)
GRASS_INFO_MESSAGE(6880,70): Attaching islands...
GRASS_INFO_END(6880,70)
GRASS_INFO_MESSAGE(6880,71): Attaching centroids...
GRASS_INFO_END(6880,71)
GRASS_INFO_MESSAGE(6880,72): Number of nodes: 9792
GRASS_INFO_END(6880,72)
GRASS_INFO_MESSAGE(6880,73): Number of primitives: 14627
GRASS_INFO_END(6880,73)
GRASS_INFO_MESSAGE(6880,74): Number of points: 0
GRASS_INFO_END(6880,74)
GRASS_INFO_MESSAGE(6880,75): Number of lines: 0
GRASS_INFO_END(6880,75)
GRASS_INFO_MESSAGE(6880,76): Number of boundaries: 9791
GRASS_INFO_END(6880,76)
GRASS_INFO_MESSAGE(6880,77): Number of centroids: 4836
GRASS_INFO_END(6880,77)
GRASS_INFO_MESSAGE(6880,78): Number of areas: 4836
GRASS_INFO_END(6880,78)
GRASS_INFO_MESSAGE(6880,79): Number of isles: 1
GRASS_INFO_END(6880,79)
GRASS_INFO_MESSAGE(6880,80):
GRASS_INFO_END(6880,80)
GRASS_INFO_WARNING(6880,81): Errors were encountered during the import
GRASS_INFO_END(6880,81)
GRASS_INFO_MESSAGE(6880,82): Try to import again, snapping with at
least 1e-010: 'snap=1e-010'
GRASS_INFO_END(6880,82)
C:\qgis\bin>g.region n=448790.113802 s=-406706.831024 e=942489.861849
C:\qgis\bin>v.dissolve input=tmp13797900260521 column=dissolve
GRASS_INFO_MESSAGE(4852,1): Building topology for vector map ...
GRASS_INFO_END(4852,1)
GRASS_INFO_MESSAGE(4852,2): Registering primitives...
GRASS_INFO_END(4852,2)
GRASS_INFO_MESSAGE(4852,3): 14627 primitives registered
GRASS_INFO_END(4852,3)
GRASS_INFO_MESSAGE(4852,4): 24555 vertices registered
GRASS_INFO_END(4852,4)
GRASS_INFO_MESSAGE(4852,5): Building areas...
GRASS_INFO_END(4852,5)
GRASS_INFO_MESSAGE(4852,6): 4836 areas built
GRASS_INFO_END(4852,6)
GRASS_INFO_MESSAGE(4852,7): 1 isles built
GRASS_INFO_END(4852,7)
GRASS_INFO_MESSAGE(4852,8): Attaching islands...
GRASS_INFO_END(4852,8)
GRASS_INFO_MESSAGE(4852,9): Attaching centroids...
GRASS_INFO_END(4852,9)
GRASS_INFO_MESSAGE(4852,10): Number of nodes: 9792
GRASS_INFO_END(4852,10)
GRASS_INFO_MESSAGE(4852,11): Number of primitives: 14627
GRASS_INFO_END(4852,11)
GRASS_INFO_MESSAGE(4852,12): Number of points: 0
GRASS_INFO_END(4852,12)
GRASS_INFO_MESSAGE(4852,13): Number of lines: 0
GRASS_INFO_END(4852,13)
GRASS_INFO_MESSAGE(4852,14): Number of boundaries: 9791
GRASS_INFO_END(4852,14)
GRASS_INFO_MESSAGE(4852,15): Number of centroids: 4836
GRASS_INFO_END(4852,15)
GRASS_INFO_MESSAGE(4852,16): Number of areas: 4836
GRASS_INFO_END(4852,16)
GRASS_INFO_MESSAGE(4852,17): Number of isles: 1
GRASS_INFO_END(4852,17)
GRASS_INFO_MESSAGE(4852,18): v.reclass complete. 4840 features reclassed.
GRASS_INFO_END(4852,18)
GRASS_INFO_ERROR(3688,1): Vector map not found in the current mapset
GRASS_INFO_END(3688,1)
C:\qgis\bin>set
C:\qgis\bin>set
C:\qgis\bin>set
C:\qgis\bin>v.out.ogr -e input=outputcd3563ec198c4675b82ed436eef6acf2
GRASS_INFO_ERROR(4012,1): Vector map not found
GRASS_INFO_END(4012,1)
C:\qgis\bin>exit
Converting outputs
Loading resulting layers
sharing a common category number or attribute. finished
