[Qgis-developer] QGIS 2.0 Win standalone busted
Victor Olaya
volayaf at gmail.com
Sat Sep 21 09:06:12 PDT 2013
I had a closer look at the problem with GRASS and the 64 bit installer
(which I guess ight be the same in other installers that do not work
correctly). It passes the test fine (the test that uses the points.shp
file), so it lets you get to the dialog. Vector operations (like the
test one) work fine, but rasters do not. Processing calls GRASS
correctly and detects the path without problems, but then GRASS
complains that "It was not possible to load GDAL library".
Giovanni, your problems are with raster layers as well, i guess, since
you can open the dialogs (meaning that vector modules run fine)
Is this a packaging problem? I have no idea about how to fix this...
Any GRASS (or packaging) expert can tell us why GRASS cannot load GDAL
Thanks!
2013/9/21 Victor Olaya <volayaf at gmail.com>:
>> The error (in the qgis log) is
>> OGR[3] error 4: Unable to open
>> C:/PROGRA~1/QGISDU~1/apps/qgis/./python/plugins\processing\tests\data\points.shp
>> or C:/PROGRA~1/QGISDU~1/apps/qgis/./python/plugins\processing\tests\data\points.SHP.
>> and this "points.shp" has nothing to do with the module being run.
> That is a layer that is used to run a test, to check that GRASS and
> SAGA are installed. Maybe when the data is in a path with blank spaces
> (as this case, since that data is in the Processing folder), GRASS
> doesn't like it?
