[Qgis-developer] QGIS 2.0 Win standalone busted
Victor Olaya
volayaf at gmail.com
Sat Sep 21 08:50:26 PDT 2013
> The error (in the qgis log) is
> OGR[3] error 4: Unable to open
> C:/PROGRA~1/QGISDU~1/apps/qgis/./python/plugins\processing\tests\data\points.shp
> or C:/PROGRA~1/QGISDU~1/apps/qgis/./python/plugins\processing\tests\data\points.SHP.
> and this "points.shp" has nothing to do with the module being run.
That is a layer that is used to run a test, to check that GRASS and
SAGA are installed. Maybe when the data is in a path with blank spaces
(as this case, since that data is in the Processing folder), GRASS
doesn't like it?
