[Qgis-developer] OS X 2.0 packages update
Andreas Neumann a.neumann at carto.net
Wed Sep 25 01:24:29 PDT 2013
 Hi William,
 Thank you for your continuous support on this issue.
 Unfortunately, GRASS still does not work in my processing environment.
 It still complains about missing dependencies.
 In parallel to Processing I am also testing the GRASS plugin.
 I can successfully create new MAPSETs and open them. The modules are
 found, but when loading one, e.g. v.surf.rst, I get this error message:
 Kann Modul v.surf.rst nicht starten
 DYLD_LIBRARY_PATH=
 QGIS_PREFIX_PATH=
 Befehl: /Applications/QGIS.app/Contents/MacOS/grass/bin/v.surf.rst
 --interface-description
 dyld: Library not loaded: /usr/local/lib/libfftw3.3.dylib Referenced
 /Applications/QGIS.app/Contents/MacOS/grass/lib/libgrass_gmath.6.4.3.dylib
 Reason: image not found
 so it seems to complain about "libfftw3.3.dylib"
 Andreas
 On Tue, 24 Sep 2013 20:24:55 -0500, William Kyngesburye wrote:
> I did a link hunt and fixed up all the link errors I could find, and
> took care of some other packaging problems.
> Also, Snow Leopard package is now ready.
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> "History is an illusion caused by the passage of time, and time is an
> illusion caused by the passage of history."
> - Hitchhiker's Guide to the Galaxy
> Qgis-developer mailing list
