[Qgis-developer] OS X 2.0 packages update
William Kyngesburye woklist at kyngchaos.com
Wed Sep 25 06:42:20 PDT 2013
Very odd, the package has this library link correct.  Try deleting QGIS.app and reinstalling.
On Sep 25, 2013, at 3:24 AM, Andreas Neumann wrote:
> Hi William,
> Thank you for your continuous support on this issue.
> Unfortunately, GRASS still does not work in my processing environment. It still complains about missing dependencies.
> In parallel to Processing I am also testing the GRASS plugin.
> I can successfully create new MAPSETs and open them. The modules are found, but when loading one, e.g. v.surf.rst, I get this error message:
> Kann Modul v.surf.rst nicht starten
> DYLD_LIBRARY_PATH=
> QGIS_PREFIX_PATH=
> Befehl: /Applications/QGIS.app/Contents/MacOS/grass/bin/v.surf.rst --interface-description
> dyld: Library not loaded: /usr/local/lib/libfftw3.3.dylib Referenced from: /Applications/QGIS.app/Contents/MacOS/grass/lib/libgrass_gmath.6.4.3.dylib Reason: image not found
> so it seems to complain about "libfftw3.3.dylib"
> Andreas
> On Tue, 24 Sep 2013 20:24:55 -0500, William Kyngesburye wrote:
>> I did a link hunt and fixed up all the link errors I could find, and
>> took care of some other packaging problems.
>> Also, Snow Leopard package is now ready.
>> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
>> http://www.kyngchaos.com/
>> "History is an illusion caused by the passage of time, and time is an
>> illusion caused by the passage of history."
>> - Hitchhiker's Guide to the Galaxy
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
"History is an illusion caused by the passage of time, and time is an illusion caused by the passage of history."
