[Qgis-developer] OS X 2.0 packages update
William Kyngesburye
woklist at kyngchaos.com
Wed Sep 25 06:52:09 PDT 2013
Again, very odd, it's correct in the installer package. Try deleting QGIS.app and reinstalling.
On Sep 25, 2013, at 8:45 AM, Noli Sicad wrote:
> Hi William,
> The OTB plugin is still not working in this update.
> I will send you a screenshot of the error.
> Noli
> On 9/25/13, William Kyngesburye <woklist at kyngchaos.com> wrote:
>> Very odd, the package has this library link correct. Try deleting QGIS.app
>> and reinstalling.
>> On Sep 25, 2013, at 3:24 AM, Andreas Neumann wrote:
>>> Hi William,
>>> Thank you for your continuous support on this issue.
>>> Unfortunately, GRASS still does not work in my processing environment. It
>>> still complains about missing dependencies.
>>> In parallel to Processing I am also testing the GRASS plugin.
>>> I can successfully create new MAPSETs and open them. The modules are
>>> found, but when loading one, e.g. v.surf.rst, I get this error message:
>>> Kann Modul v.surf.rst nicht starten
>>> DYLD_LIBRARY_PATH=
>>> QGIS_PREFIX_PATH=
>>> Befehl: /Applications/QGIS.app/Contents/MacOS/grass/bin/v.surf.rst
>>> --interface-description
>>> dyld: Library not loaded: /usr/local/lib/libfftw3.3.dylib Referenced from:
>>> /Applications/QGIS.app/Contents/MacOS/grass/lib/libgrass_gmath.6.4.3.dylib
>>> Reason: image not found
>>> so it seems to complain about "libfftw3.3.dylib"
>>> Andreas
>>> On Tue, 24 Sep 2013 20:24:55 -0500, William Kyngesburye wrote:
>>>> I did a link hunt and fixed up all the link errors I could find, and
>>>> took care of some other packaging problems.
>>>> Also, Snow Leopard package is now ready.
>>>> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
>>>> http://www.kyngchaos.com/
>>>> "History is an illusion caused by the passage of time, and time is an
>>>> illusion caused by the passage of history."
>>>> - Hitchhiker's Guide to the Galaxy
>>>> _______________________________________________
>>>> Qgis-developer mailing list
>>>> Qgis-developer at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
First Pogril: Why is life like sticking your head in a bucket filled with hyena offal?
Second Pogril: I don't know. Why IS life like sticking your head in a bucket filled with hyena offal?
First Pogril: I don't know either. Wretched, isn't it?
-HitchHiker's Guide to the Galaxy
