[Qgis-developer] OS X 2.0 packages update
Noli Sicad
nsicad at gmail.com
Wed Sep 25 07:08:04 PDT 2013
I deleted QGIS.app before installing.
I deleted QGIS.app again and reinstalled. Yet I got the same problem,
OTB is not working as showed in the screenshot that I sent you.
Noli
On 9/25/13, William Kyngesburye <woklist at kyngchaos.com> wrote:
> Again, very odd, it's correct in the installer package. Try deleting
> QGIS.app and reinstalling.
> On Sep 25, 2013, at 8:45 AM, Noli Sicad wrote:
>> Hi William,
>> The OTB plugin is still not working in this update.
>> I will send you a screenshot of the error.
>> Noli
>>> Very odd, the package has this library link correct. Try deleting
>>> QGIS.app
>>> and reinstalling.
>>> On Sep 25, 2013, at 3:24 AM, Andreas Neumann wrote:
>>>> Hi William,
>>>> Thank you for your continuous support on this issue.
>>>> Unfortunately, GRASS still does not work in my processing environment.
>>>> It
>>>> still complains about missing dependencies.
>>>> In parallel to Processing I am also testing the GRASS plugin.
>>>> I can successfully create new MAPSETs and open them. The modules are
>>>> found, but when loading one, e.g. v.surf.rst, I get this error message:
>>>> Kann Modul v.surf.rst nicht starten
>>>> DYLD_LIBRARY_PATH=
>>>> QGIS_PREFIX_PATH=
>>>> Befehl: /Applications/QGIS.app/Contents/MacOS/grass/bin/v.surf.rst
>>>> --interface-description
>>>> dyld: Library not loaded: /usr/local/lib/libfftw3.3.dylib Referenced
>>>> from:
>>>> /Applications/QGIS.app/Contents/MacOS/grass/lib/libgrass_gmath.6.4.3.dylib
>>>> Reason: image not found
>>>> so it seems to complain about "libfftw3.3.dylib"
>>>> Andreas
>>>> On Tue, 24 Sep 2013 20:24:55 -0500, William Kyngesburye wrote:
>>>>> I did a link hunt and fixed up all the link errors I could find, and
>>>>> took care of some other packaging problems.
>>>>> Also, Snow Leopard package is now ready.
>>>>> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
>>>>> http://www.kyngchaos.com/
>>>>> "History is an illusion caused by the passage of time, and time is an
>>>>> illusion caused by the passage of history."
>>>>> - Hitchhiker's Guide to the Galaxy
>>>>> _______________________________________________
>>>>> Qgis-developer mailing list
>>>>> Qgis-developer at lists.osgeo.org
>>>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
> First Pogril: Why is life like sticking your head in a bucket filled with
> hyena offal?
> Second Pogril: I don't know. Why IS life like sticking your head in a
> bucket filled with hyena offal?
> First Pogril: I don't know either. Wretched, isn't it?
> -HitchHiker's Guide to the Galaxy
