[Qgis-developer] import CSV to an existing layer
Nathan Woodrow madmanwoo at gmail.com
Fri Sep 27 05:26:36 PDT 2013
I don't think having three steps is a bad thing per se.  To me the workflow
is a lot clearer, expandable, and fixable.  This function doesn't belong in
the add layer dialogs because it's not their purpose.  What happens if I
wanted to append a shape file to a MS SQL layer?   This is why I think it
should be a higher level function that just take two layers and a field
mapping and runs though layer1 and appends to layer2
- Nathan
On Fri, Sep 27, 2013 at 10:08 PM, Denis Rouzaud <denis.rouzaud at gmail.com>wrote:
>  Hi Nathan,
> I understand your point.
> But this would require more steps: add the layer to the project, copy the
> features (with field mapping) and remove the layer.
> I see a main usage of appending to an existing layer in the import of GPS
> points for example. So mainly csv files.
> It's true that there could be a great interest for shape files.
> The point is that I can use the existing header of the table in the
> demilited text UI to do the field mapping. So, it should not be a great
> effort to do so.
> It's clear that there is no a great cohesion with all these add layers
> dialogs and I don't want to add more confusion to this.
> But is there any plan to improve this?
> Denis
> On 09/27/2013 01:43 PM, Nathan Woodrow wrote:
> I think a general higher level Append Features to Layer feature would be
> much better.  This way it would work with any layer opened in QGIS.
> Being able to supply a layer to layer mapping would be even better in case
> the fields don't match.
>  - Nathan
> On Fri, Sep 27, 2013 at 9:34 PM, Denis Rouzaud <denis.rouzaud at gmail.com>wrote:
>> Hi all,
>> I have the intention to add the possibility of importing features from a
>> CSV into an existing layer.
>> My idea is to use the existing dialog "Create a layer from a delimited
>> text file" and to add the choice "create a layer" or "append to an existing
>> layer".
>> First of all, is anyone already doing something similar?
>> Second, if anyone already thought about this and has some ideas to share,
>> they're welcome!
>> Cheers,
>> Denis
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20130927/eeea1a39/attachment.html>
