[Qgis-developer] OS X 2.0 packages update
William Kyngesburye
woklist at kyngchaos.com
Sat Sep 28 12:26:07 PDT 2013
Just an hour ago I discovered a problem with the bundled GRASS.
Quick fix, in a Terminal:
sudo chmod +x /Applications/QGIS.app/Contents/MacOS/grass/grass.sh
I'll package an update later.
QGIS has its own bundled GRASS, and should find it automatically. It should be possible to use an installed GRASS, but you have to know what to enter for the path (not the .app, but the MacOS folder inside the app).
On Sep 28, 2013, at 2:14 PM, Noli Sicad wrote:
> Hi William,
> Yes, OTB plugin is working now. I read the QGIS user ML archive ( Re:
> OS X 2.0 packages - Try) update and found out there is a new version
> of the installer, so download it and installed it before your email
> below.
> Now, I am trying to figure out why my GRASS plugin is still now not
> working in Processing. It seems "Processing" could not still find the
> right things to run GRASS. Any suggestion how to fix this issue?
> BTW, I also installed GRASS standalone in my system. I understand this
> might not be needed to run the GRASS Plugin in "Processing".
> Thanks again.
> Regards, Noli
> On 9/28/13, William Kyngesburye <woklist at kyngchaos.com> wrote:
>> I understand. And I'm saying that that link error (and many others) is
>> fixed in the current build. You don't need anything else installed for OTB
>> to work, OTB and the libraries/frameworks linked are included in QGIS.app.
>> Note that when I re-fixed the installer I didn't bump the version number
>> (because the broken package was still the old package), so make sure to
>> download it again.
>> On Sep 27, 2013, at 8:49 PM, Noli Sicad wrote:
>>> Hi William,
>>> In the last screenshot on the OTB Plugin for QGIS 2.0.1-2 Mac OS X
>>> error that I sent you, it seems that there is dynamic library that is
>>> not loading.
>>> "dylb: Library not loaded" (in the screenshot error)
>>> In compiling OTB Plugin for QGIS 2.0.1-2 Mac OS X, does OTB-Plugin
>>> requires OTB binary installed in your system?
>>> What might be this dynamic library not loading, (i.e. what is this
>>> library)?
>>> I hope we can make OTB plugin working in Mac OS X.
>>> Thanks,
>>> Regards, Noli
>>> On 9/25/13, Noli Sicad <nsicad at gmail.com> wrote:
>>>> I deleted QGIS.app before installing.
>>>> I deleted QGIS.app again and reinstalled. Yet I got the same problem,
>>>> OTB is not working as showed in the screenshot that I sent you.
>>>> Noli
>>>> On 9/25/13, William Kyngesburye <woklist at kyngchaos.com> wrote:
>>>>> Again, very odd, it's correct in the installer package. Try deleting
>>>>> QGIS.app and reinstalling.
>>>>> On Sep 25, 2013, at 8:45 AM, Noli Sicad wrote:
>>>>>> Hi William,
>>>>>> The OTB plugin is still not working in this update.
>>>>>> I will send you a screenshot of the error.
>>>>>> Noli
>>>>>>> Very odd, the package has this library link correct. Try deleting
>>>>>>> QGIS.app
>>>>>>> and reinstalling.
>>>>>>> On Sep 25, 2013, at 3:24 AM, Andreas Neumann wrote:
>>>>>>>> Hi William,
>>>>>>>> Thank you for your continuous support on this issue.
>>>>>>>> Unfortunately, GRASS still does not work in my processing
>>>>>>>> environment.
>>>>>>>> It
>>>>>>>> still complains about missing dependencies.
>>>>>>>> In parallel to Processing I am also testing the GRASS plugin.
>>>>>>>> I can successfully create new MAPSETs and open them. The modules are
>>>>>>>> found, but when loading one, e.g. v.surf.rst, I get this error
>>>>>>>> message:
>>>>>>>> Kann Modul v.surf.rst nicht starten
>>>>>>>> DYLD_LIBRARY_PATH=
>>>>>>>> QGIS_PREFIX_PATH=
>>>>>>>> Befehl: /Applications/QGIS.app/Contents/MacOS/grass/bin/v.surf.rst
>>>>>>>> --interface-description
>>>>>>>> dyld: Library not loaded: /usr/local/lib/libfftw3.3.dylib Referenced
>>>>>>>> from:
>>>>>>>> /Applications/QGIS.app/Contents/MacOS/grass/lib/libgrass_gmath.6.4.3.dylib
>>>>>>>> Reason: image not found
>>>>>>>> so it seems to complain about "libfftw3.3.dylib"
>>>>>>>> Andreas
>>>>>>>> On Tue, 24 Sep 2013 20:24:55 -0500, William Kyngesburye wrote:
>>>>>>>>> I did a link hunt and fixed up all the link errors I could find,
>>>>>>>>> and
>>>>>>>>> took care of some other packaging problems.
>>>>>>>>> Also, Snow Leopard package is now ready.
>>>>>>>>> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
>>>>>>>>> http://www.kyngchaos.com/
>>>>>>>>> "History is an illusion caused by the passage of time, and time is
>>>>>>>>> an
>>>>>>>>> illusion caused by the passage of history."
>>>>>>>>> - Hitchhiker's Guide to the Galaxy
>>>>>>>>> _______________________________________________
>>>>>>>>> Qgis-developer mailing list
>>>>>>>>> Qgis-developer at lists.osgeo.org
>>>>>>>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
>>>>>>> "History is an illusion caused by the passage of time, and time is an
>>>>> First Pogril: Why is life like sticking your head in a bucket filled
>>>>> with
>>>>> hyena offal?
>>>>> Second Pogril: I don't know. Why IS life like sticking your head in a
>>>>> bucket filled with hyena offal?
>>>>> First Pogril: I don't know either. Wretched, isn't it?
>>>>> -HitchHiker's Guide to the Galaxy
>> First Pogril: Why is life like sticking your head in a bucket filled with
>> hyena offal?
"Time is an illusion - lunchtime doubly so."
- Ford Prefect
