[Qgis-developer] OS X 2.0 packages update
    Andreas Neumann
    a.neumann at carto.net
    Sun Sep 29 09:54:47 PDT 2013
Hi William,
This did the track. I can confirm that GRASS within Processing now works
fine on OSX once I manually set these executable permission for the
grass.sh file.
Thanks a lot for finding this out.
Andreas
Am 28.09.2013 21:26, schrieb William Kyngesburye:
> Just an hour ago I discovered a problem with the bundled GRASS.
> Quick fix, in a Terminal:
> sudo chmod +x /Applications/QGIS.app/Contents/MacOS/grass/grass.sh
> I'll package an update later.
> QGIS has its own bundled GRASS, and should find it automatically.  It should be possible to use an installed GRASS, but you have to know what to enter for the path (not the .app, but the MacOS folder inside the app).
> On Sep 28, 2013, at 2:14 PM, Noli Sicad wrote:
