[Qgis-developer] install instructions
Barry Rowlingson
b.rowlingson at lancaster.ac.uk
Mon Sep 30 09:54:39 PDT 2013
Tried adding that PPA, now saga conflicts with itself in synaptic.
And if I install with apt-get it removes Qgis. If I try and install
Qgis, it removes Saga.
$ sudo apt-get install saga
currently says
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies.
saga : Depends: libgdal1 (>= 1.8.0) but it is not going to be installed
Depends: liblas1 but it is not going to be installed
trying to install libgdal1 results in qgis and a bunch of other
packages being REMOVED (in capitals) - I guess because they use
libgdal1h? Whatever that is.
I'm a bit disappointed that I've started from a clean, modern Ubuntu
install (ok, Mint) and am instantly in some kind of dependency hell. I
was hoping it would be "add a source, get qgis, get other goodies,
play".
Does this all work off OSGeo Live 7?
On Mon, Sep 30, 2013 at 5:22 PM, Alex Mandel <tech_dev at wildintellect.com> wrote:
> On 09/30/2013 07:35 AM, Barry Rowlingson wrote:
>> On Sun, Sep 29, 2013 at 8:15 PM, Alex Mandel <tech_dev at wildintellect.com> wrote:
>>> Barry - To clarify again, the Ubuntugis version is the same version of
>>> QGIS, what differs is GDAL, PROJ and GEOS - by significant version, ie
>>> gdal 1.8 vs 1.10
>>> This is critical because 1.10.x supports more of the formats people
>>> having been asking for like HDF, etc...
>> Another annoyance: I can't get SAGA geoprocessing working. I think
>> this is because the saga version on ubuntugis-unstable is 2.0.8, but
>> QGIS requires 2.1 according to:
>> http://docs.qgis.org/2.0/html/en/docs/user_manual/processing/3rdParty.html
>> Also, those docs mention an option I can't find: the "SAGA Folder"
>> setting in the SAGA configuration. Is this supposed to be in the
>> Processing/Options and Configuration dialog in QGIS 2.0? - Maybe that
>> will either magically appear when I do get SAGA 2.1 installed or its a
>> hangover from an earlier QGIS....
>> Sorry to bring these up post-release, but I had to upgrade my machine
>> first and didn't want to do that before FOSS4G!
>> Barry
> That's a known packaging issue previous discussed with Johan.
> SAGA 2.1 requires newer wxwidgets than 12.04 has (which could also
> effect GRASS). He was hesitant to put wxwidgets in Ubuntugis. I think he
> was going to ask Victor to make it possible to still use 2.0.8 with
> Processing/Sextante, which we do have.
> Or you can get it from https://launchpad.net/~johanvdw/+archive/saga-gis
> Not sure if it will break GRASS or not.
> Last discussion on the topic was on in August.
> Thanks,
> Alex
