[Qgis-developer] Issues with GRASS plugin
Giovanni Manghi
giovanni.manghi at faunalia.pt
Tue Apr 1 12:20:17 PDT 2014
> I open a raster, click on Edit grass region, change just the resolution,
> then I run r.slope - > the resulting map has the resolution of the input
> dtm, not that defined in the previous step.
weird, now I can confirm too.
> If I add a vector from GRASS plugin>Toolbox>Browser, with double click
> or right click -> add to map, I get individual topolayers (1_polygon,
> topo_point, topo_line, topo_node).
here crashes qgis
> From QGIS browser, I get a double entry for grass locations (one as a
> folder, one as grass layers). The first does not show data, the second
> does not allow the loading of the whole layer, but only of individual
> topolayers.
> It used to behave properly.
yes I see both, and only individual layers can be loaded
> does it show also topolayers?
yes
> Moreover, creating a location from qgis extent fails.
> GRASS 6.4.3-3 and QGIS 2.2 on Debian sid, and standalone on Windows.
weird again, this seems to work here.
