[Qgis-developer] Identified features vs. Selected features : could we merge those ?
A Huarte
ahuarte47 at yahoo.es
Thu Apr 3 00:52:53 PDT 2014
+1 with Andreas for the same reasons
Related to this dicussion: regarding the form of how the elements are painted on the map, I would like to discuss an idea.
To avoid repainting the full content of the map when the selection changes (it can very heavy for big contents), I find it interesting to modify how the highlight of the elements is done by painting similar to how it does the identification tool (it uses QgsHighlight class). Basically, disconnec the rendered map to the selected elements to draw.
Best Regards
Alvaro
>>________________________________
> De: Olivier Dalang <olivier.dalang at gmail.com>
>Para: "qgis-developer at lists.osgeo.org" <qgis-developer at lists.osgeo.org>
>Enviado: Jueves 3 de abril de 2014 0:17
>Asunto: [Qgis-developer] Identified features vs. Selected features : could we merge those ?
>Hi !
>The discussions about this issue http://hub.qgis.org/issues/9907 raised the question (at least for me) of merging the concepts of Identified features and Selected features.
>I don't know if it's the good moment to discuss this, but since we have a few other threads talking about a bit more deep user interaction changes, I thought it could be good to think of this also (even if it's not urgent)...
>In short, the idea would be to have both identified features and selected features be exactly the same thing.
>The only difference between the select tool and the identify tool would then be that the identify tool opens a form window (either the single feature form or the attribute table in form mode).
>The identify tool could then also work in "single","rectangle","polygon" etc modes.
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140403/06fcfb85/attachment-0001.html>
