[Qgis-developer] Adding plugins to core?
Etienne Tourigny etourigny.dev at gmail.com
Sat Apr 5 19:11:37 PDT 2014
On Sat, Apr 5, 2014 at 1:13 PM, Etienne Tourigny <etourigny.dev at gmail.com>wrote:
> On Sat, Apr 5, 2014 at 1:00 AM, Nathan Woodrow <madmanwoo at gmail.com>wrote:
>> I agree that adding the plugins to core would be a good idea however I
>> don't feel that we should just add them in their current state.  The plugin
>> repository has the benefit of of being able to update things faster then
>> the release of QGIS itself if you find bugs, etc, you can also add features
>> for older QGIS versions.
> the processing/sextante plugin is both in core and also can be updated.
> Same thing for ftools and gdaltools.
>> I think these features in the plugins are great but we should really
>> integrate them into the core project itself as new features rather then
>> just a plugin.   Having Python plugins in core can also raise issue for
>> users because they still look like normal plugins but you can't update them
>> because they are no longer in the repository.  Having to enable handy
>> features also feels a bit hap hazard to me.
>> Something like the value tool could easily be integrated into the
>> identify tool for instance.
> I agree, more or less - I thought about integrating it into the main
> identify tool, but as it works with raster layers only, how would you
> display raster and vector layers?
I have implemented most features of the Identify Tool plugin to the main
identify map tool in master, here is the pull request.
https://github.com/qgis/QGIS/pull/1293
>> There are also some other concepts floating around the idea of bring CAD
>> functions into core so I think it's best to just focus on making those
>> stronger.
>> So +1 for adding the functions but -1 for just bringing the plugins into
>> core.
> Not sure they would make it into core then, as development cost fof
> integrating into core is much higher than adding them as core python
> modules. For instance, the openlayer plugin would probably need quite a lot
> of work to be ported to c++.
> On the other hand, anything that relies on qwt would be better handled.
> Butanthing that uses python plotting libraries would obviously not work.
> cheers
> Etienne
>> - Nathan
>> On Sat, Apr 5, 2014 at 1:22 PM, AntonioLocandro <
>> antoniolocandro at hotmail.com> wrote:
>>> I think it's a great idea, I was actually thinking about this the other
>>> day
>>> and glad you brought the topic.
>>> Although we can install plugins certainly it becomes evident when a
>>> plugin
>>> should really become a core feature, example the Openlayers Plugin, I bet
>>> almost all people using QGIS downloads it before doing anything with
>>> QGIS.
>>> Plugins extend QGIS functionality beyond what initially was thought but
>>> in
>>> many cases plugins become a must to be able to work efficiently
>>> If the plugins are added to core I would vote for blending the functions
>>> coherently with the rest of the interface in the appropriate menus. A
>>> good
>>> example would be CAD tools which I would say be called Advanced Editing
>>> or
>>> something.
>>> I would add
>>> http://plugins.qgis.org/plugins/zoomtocoordinates/
>>> http://plugins.qgis.org/plugins/numericalDigitize/  - needs to add case
>>> for
>>> geographic coordinates
>>> View this message in context:
>>> http://osgeo-org.1560.x6.nabble.com/Adding-plugins-to-core-tp5133202p5133245.html
>>> Sent from the Quantum GIS - Developer mailing list archive at Nabble.com.
>>> Qgis-developer mailing list
>>> Qgis-developer at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140405/dbf8c8e9/attachment.html>
