[Qgis-developer] Adding plugins to core?
Etienne Tourigny etourigny.dev at gmail.com
Mon Apr 7 07:48:44 PDT 2014
Since the OpenLayers plugin does not (currently) work with master, perhaps
we can replace it with TMS-based layers, either through a plugin or as a
native (GDAL-based) provider?
Is there anything in OpenLayers plugin that could not work with GDAL TMS
mini-driver [1] ?
[1] http://www.gdal.org/frmt_wms.html
On Mon, Apr 7, 2014 at 11:42 AM, Etienne Tourigny
> we can replace it with TMS-based layers, wither through a plugin or as a
> Is there anything in OpenLayers that could not work with GDAL TMS
> mini-driver [1] ?
> On Mon, Apr 7, 2014 at 7:22 AM, Vincent Picavet <vincent.ml at oslandia.com>wrote:
>> Hello,
>> Le lundi 7 avril 2014 12:05:05, Nyall Dawson a écrit :
>> > On 7 April 2014 18:15, Vincent Picavet <vincent.ml at oslandia.com> wrote:
>> > > A good solution though would be to remove google layers and only use
>> OSM
>> > > and mapbox layers, which begin to be on par in terms of quality.
>> > I'm pretty sure this is against MapBox's terms of service too, unless
>> > users were made to sign up for a MapBox account and had to add their
>> > individual API key to QGIS to unlock MapBox layers:
>> > "You must have a Mapbox account to use Mapbox. You are required to
>> > register for an account before using the Service. Each request to the
>> > API must include your account's unique API identifier. Unauthorized
>> > use of any API identifier is prohibited." [1]
>> Right, I had not read this through. It would probably be much easier to
>> get a
>> specific authorization from MapBox than from Google though, given their
>> open-
>> source orientation.
>> > > Or let the user a
>> > > deliberate way to add google layers (indicating a URL or something
>> like
>> > > this), warning him about the licence.
>> > Hmm... while this may be a workable solution to the licensing issue,
>> > wouldn't it be a step back in functionality anyway? We'd be trading
>> > having a good, working off-the-shelf third-party plugin for a crippled
>> > core version which takes user intervention to unlock the same
>> > features.
>> In any case, there are quite a lot of OSM based layers which can be used
>> (HOT,
>> OSM.fr, OpenCycleMap...). We can still enhance the plugin with those.
>> It would lack an aerial imagery layer though.
>> > I'm totally for adding essential plugins to core (or merging the
>> > functionality with reimplemented c++ versions), but I honestly don't
>> > know if it's workable to do this for the OpenLayers plugin.
>> Right, if we remove everything from the plugin except the TMS YXZ layers,
>> we
>> could also just have a better ergonomy for opening this kind of layers
>> through
>> GDAL, and have a predefined list of layers accessible on internet (even
>> auto-
>> updatable by downloading the list).
>> Vincent
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140407/7106a91d/attachment.html>
