[Qgis-developer] How to get renderComplete painter reference
Mathieu Pellerin
nirvn.asia at gmail.com
Sun Apr 6 17:36:42 PDT 2014
Anita, just saw you commited a fix. Thanks!
May I suggest a small improvement? You should calculate the time it took,
in ms, to render canvas and deduce that ms value from the
animationFrameLength ms value in your singleShot call:
QTimer.singleShot(self.animationFrameLength,self.playAnimation)
Currently if you have a 1000ms frame length and canvas rendering takes
500ms, each frame will last 1500ms. Deducing the 500ms canvas rendering
time from frame length will fix this. If rendering ms > frame length ms,
that'd allow you to skip singleShot and render next frame immediately.
Cheers and thanks again.
Math
On 6 Apr 2014 23:08, "Anita Graser" <anitagraser at gmx.at> wrote:
> Hi,
> I need the painter from the renderComplete signal? Could you help me with
> the correct syntax?
> I have:
> self.iface.mapCanvas().renderComplete.connect(self.
> waitAfterRenderComplete)
> and
> def waitAfterRenderComplete(self, painter):
> but waitAfterRenderComplete does not receive a painter.
> Thanks and best wishes,
> Anita
> anitagraser.com
> Qgis-developer mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140407/bd5dca17/attachment.html>
