[Qgis-developer] Adding plugins to core?
kimaidou kimaidou at gmail.com
Mon Apr 7 13:41:53 PDT 2014
Hi Victor
For me, core features (and not core plugins) are much more integrated into
QGIS ui and dialogs. For example, tablemanager plugins adds some nice
features , but they should be integrated in the Fields tab of the vector
layer properties. Having the features separated in a plugin (core or not
core) adds complexity for users.
For other plugins like mmqgis, which brings a list of algorithms , I agree
there is no big difference between plugin and feature.
I think we won't find a common rule for all the plugins. We should have a
look plugin by plugin, otherwise our discussion will go in every direction.
Michael
2014-04-07 21:43 GMT+02:00 Victor Olaya <volayaf at gmail.com>:
> I actually do not see the difference between a core plugin a something
> implemented directly in the core c++ code. Other than the extra time
> it might take to develop it. The user doesn't have to know it is a
> plugin, and it should be easy to actually remove a core plugin from
> the plugin manager (like black-listing it), so it doesn't appear
> there.
> 2014-04-07 20:05 GMT+02:00 Olivier Dalang <olivier.dalang at gmail.com>:
> > Hi !
> > I agree with those saying it's better to integrate the features of
> > top-plugin in the core, if we find the features are worth it, and if
> someone
> > has the time to do so, rather than shipping dozens of preinstalled
> plugin.
> > I don't like the impression it gives to have a brand new software already
> > "bloated" by plugins, which you never really know what they do and if
> it's
> > OK or not to remove them.
> > A better alternative IMO is to display the "featured" plugins category
> as a
> > tab in the plugin manager, but not to preinstall them.
> > It could even become the default page of the plugin manager.
> > I personally feel much better when adding by myself suggested plugins
> than
> > when hesitating to remove a plugin which I'm not really sure what it's
> about
> > but seems kinda-important since it already was installed...
> > About this, please consider this ticket also :
> > http://hub.qgis.org/issues/9405
> > Cheers !
> > Olivier
> > 2014-04-07 19:41 GMT+02:00 Etienne Tourigny <etourigny.dev at gmail.com>:
> >> Thanks for the links. Most of this information is also available at [1].
> >> I am preparing a simple plugin to load these layers  as raster layers,
> >> will keep you updated on this.
> >> [1] http://www.gdal.org/frmt_wms.html
> >> On Mon, Apr 7, 2014 at 2:32 PM, kimaidou <kimaidou at gmail.com> wrote:
> >>> Hi List
> >>> For the record, here is an old blog post about using gdal driver to
> >>> use external layers such as OSM
> http://www.3liz.com/blog/rldhont/index.php?post/2012/07/17/OpenStreetMap-Tiles-in-QGIS
> >>> The problem is that with this method, it seems GDAL does not alway use
> >>> the right tiles for the rigth scale. There must be an additionnal
> >>> parameter wich can control this behaviour.
> >>> I totally agree with the concerns about licence violation. Easing the
> >>> use of Google layers is kind of encouraging people to use it, for
> >>> example for digitization purpose. Users must be warned about the terms
> >>> of service.
> >>> Michael
> >>> PS : someone has gathered a list of XML for GDAL for some providers :
> http://libreavous.teledetection.fr/geomatique/28-sig/58-afficher-des-couches-issues-de-services-en-ligne-dans-un-sig
> >>> Click on the button called "Fichiers de configuration ...."
> >>> Michael
> >>> 2014-04-07 16:48 UTC+02:00, Etienne Tourigny <etourigny.dev at gmail.com
> >>> > Since the OpenLayers plugin does not (currently) work with master,
> >>> > perhaps
> >>> > we can replace it with TMS-based layers, either through a plugin or
> as
> >>> > a
> >>> > native (GDAL-based) provider?
> >>> > Is there anything in OpenLayers plugin that could not work with GDAL
> >>> > TMS
> >>> > mini-driver [1] ?
> >>> > On Mon, Apr 7, 2014 at 11:42 AM, Etienne Tourigny
> >>> >> perhaps
> >>> >> we can replace it with TMS-based layers, wither through a plugin or
> as
> >>> >> a
> >>> >> Is there anything in OpenLayers that could not work with GDAL TMS
> >>> >> mini-driver [1] ?
> >>> >> On Mon, Apr 7, 2014 at 7:22 AM, Vincent Picavet
> >>> >> <vincent.ml at oslandia.com>wrote:
> >>> >>> Hello,
> >>> >>> Le lundi 7 avril 2014 12:05:05, Nyall Dawson a écrit :
> >>> >>> > On 7 April 2014 18:15, Vincent Picavet <vincent.ml at oslandia.com>
> >>> >>> > wrote:
> >>> >>> > > A good solution though would be to remove google layers and
> only
> >>> >>> > > use
> >>> >>> OSM
> >>> >>> > > and mapbox layers, which begin to be on par in terms of
> quality.
> >>> >>> > I'm pretty sure this is against MapBox's terms of service too,
> >>> >>> > unless
> >>> >>> > users were made to sign up for a MapBox account and had to add
> >>> >>> > their
> >>> >>> > individual API key to QGIS to unlock MapBox layers:
> >>> >>> > "You must have a Mapbox account to use Mapbox. You are required
> to
> >>> >>> > register for an account before using the Service. Each request to
> >>> >>> > the
> >>> >>> > API must include your account's unique API identifier.
> Unauthorized
> >>> >>> > use of any API identifier is prohibited." [1]
> >>> >>> Right, I had not read this through. It would probably be much
> easier
> >>> >>> to
> >>> >>> get a
> >>> >>> specific authorization from MapBox than from Google though, given
> >>> >>> their
> >>> >>> open-
> >>> >>> source orientation.
> >>> >>> > > Or let the user a
> >>> >>> > > deliberate way to add google layers (indicating a URL or
> >>> >>> > > something
> >>> >>> like
> >>> >>> > > this), warning him about the licence.
> >>> >>> > Hmm... while this may be a workable solution to the licensing
> >>> >>> > issue,
> >>> >>> > wouldn't it be a step back in functionality anyway? We'd be
> trading
> >>> >>> > having a good, working off-the-shelf third-party plugin for a
> >>> >>> > crippled
> >>> >>> > core version which takes user intervention to unlock the same
> >>> >>> > features.
> >>> >>> In any case, there are quite a lot of OSM based layers which can be
> >>> >>> used
> >>> >>> (HOT,
> >>> >>> OSM.fr, OpenCycleMap...). We can still enhance the plugin with
> those.
> >>> >>> It would lack an aerial imagery layer though.
> >>> >>> > I'm totally for adding essential plugins to core (or merging the
> >>> >>> > functionality with reimplemented c++ versions), but I honestly
> >>> >>> > don't
> >>> >>> > know if it's workable to do this for the OpenLayers plugin.
> >>> >>> Right, if we remove everything from the plugin except the TMS YXZ
> >>> >>> layers,
> >>> >>> we
> >>> >>> could also just have a better ergonomy for opening this kind of
> >>> >>> layers
> >>> >>> through
> >>> >>> GDAL, and have a predefined list of layers accessible on internet
> >>> >>> (even
> >>> >>> auto-
> >>> >>> updatable by downloading the list).
> >>> >>> Vincent
> >>> >>> _______________________________________________
> >>> >>> Qgis-developer mailing list
> >>> >>> Qgis-developer at lists.osgeo.org
> >>> >>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140407/7275b481/attachment-0001.html>
