[Qgis-developer] working with qgis and pgadmin/psql...
Giovanni Manghi
giovanni.manghi at faunalia.pt
Wed Apr 9 11:45:51 PDT 2014
Hi Martin,
thanks for the answer.
> What versions are affected - dev / 2.2 / both?
I think both, for sure on master.
> What happens with QGIS / DB manager open? Waiting indefinitely / crash / ... ?
it happens that pgadmin/psql operations remain "freezed", then when
closing qgis they immediately start and finish as expected.
> Maybe you are running out of available connections on the PostgreSQL
> server - increasing their number in server configuration may help.
on my local machine, for local work (just one user connected, me) I
have set postgresql.conf to accept max 100 connections, and still this
issue.
Should I put an higher value?
cheers!
-- G --
