[Qgis-developer] [Processing] operations in batch mode
skampus skampus at gmail.com
Fri Apr 11 07:57:23 PDT 2014
hello to all,
I have to make massive operations of "intersect" between postgis layers and
one simple area of extraction (shape file).
I was thinking of using a module of Processing (in particular the "shapes
cut" saga module) in batch mode.
I immediately stopped because all operations can be performed only on data
sets that exist on the file system (shape, kml, etc.) so I can not use
postgis tables directly.
I should first convert the tables into shapes and then use the function
intersect in the batch but this should be done "manually", taking up a lot
of disk space, and in any case it would be an extra step.
is there a reason why all operations in batch mode have to be performed only
with shape files et similia?
ciao
s.
View this message in context: http://osgeo-org.1560.x6.nabble.com/Processing-operations-in-batch-mode-tp5134629.html
Sent from the Quantum GIS - Developer mailing list archive at Nabble.com.
