[Qgis-developer] [Processing] operations in batch mode
Victor Olaya
volayaf at gmail.com
Fri Apr 11 08:10:13 PDT 2014
I cannot think of any reason right now, so it looks like I designed it
like that and did not consider that alternative. My fault :-(
Could you add a ticket in the issue tracker, with this as a feature
request? I will try to work on that I will crearly be a good
improvement
Thanks for the idea!
2014-04-11 16:57 GMT+02:00 skampus <skampus at gmail.com>:
> hello to all,
> I have to make massive operations of "intersect" between postgis layers and
> one simple area of extraction (shape file).
> I was thinking of using a module of Processing (in particular the "shapes
> cut" saga module) in batch mode.
> I immediately stopped because all operations can be performed only on data
> sets that exist on the file system (shape, kml, etc.) so I can not use
> postgis tables directly.
> I should first convert the tables into shapes and then use the function
> intersect in the batch but this should be done "manually", taking up a lot
> of disk space, and in any case it would be an extra step.
> is there a reason why all operations in batch mode have to be performed only
> with shape files et similia?
> ciao
> s.
> View this message in context: http://osgeo-org.1560.x6.nabble.com/Processing-operations-in-batch-mode-tp5134629.html
> Sent from the Quantum GIS - Developer mailing list archive at Nabble.com.
> Qgis-developer mailing list
