[Qgis-developer] #8884 Symbol too small in legend when map units are used
Luca Manganelli luca76 at gmail.com
Tue Apr 15 06:09:23 PDT 2014
Hi, anyone having issues with this bug?
Simple test case: pick a vectorial point layer with the default style, see
the TOC legend;
open the style properties, go to Style and switch the units to "Map units".
As you can see, the symbol is very small. The situation is worse if you use
a SVG symbol, it's impossible to distinguish which is on the map and which
is on the legend.
https://hub.qgis.org/issues/8884
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140415/4146b6d7/attachment.html>
