[Qgis-developer] Fwd: #8884 Symbol too small in legend when map units are used
Luca Manganelli
luca76 at gmail.com
Tue Apr 15 23:54:25 PDT 2014
Forwarding to qgis-developer mailing list (he wrote to me :-) )
---------- Forwarded message ----------
Date: Tue, Apr 15, 2014 at 3:14 PM
Subject: Re: [Qgis-developer] #8884 Symbol too small in legend when map
units are used
To: Luca Manganelli <luca76 at gmail.com>
Confirmed. We would need a way to override the symbol map unit size with a
size mm - solely for the display of the legend.
Andreas
Am 2014-04-15 15:09, schrieb Luca Manganelli:
> Hi, anyone having issues with this bug?
> Simple test case: pick a vectorial point layer with the default style,
> see the TOC legend;
> open the style properties, go to Style and switch the units to "Map
> units". As you can see, the symbol is very small. The situation is
> worse if you use a SVG symbol, it's impossible to distinguish which is
> on the map and which is on the legend.
> https://hub.qgis.org/issues/8884 [1]
> Links:
> [1] https://hub.qgis.org/issues/8884
> Qgis-developer mailing list
It means your future hasn't been written yet. No one's has. Your future is
whatever you make it. So make it a good one, both of you.
-- Doc Brawn, Back to the Future III (1990)
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140416/8dc1de19/attachment.html>
