[Qgis-developer] Processing: default resolution
Victor Olaya
volayaf at gmail.com
Thu Apr 17 04:28:09 PDT 2014
Not sure this is a easy fix
In SAGA, some algorithms require that resolution, when a new raster
layers is created and there is not a raster input (interpolation,
rasterization...) In GRASS, that is a parameter of the region, which
complicates things.
If there are suggestions, I will be happy to change whatever is needed
in the GRASS provider
2014-04-17 13:02 GMT+02:00 Paolo Cavallini <cavallini at faunalia.it>:
> Hi all.
> I noticed an inconsistency in how the default resolution is handled in
> GRASS and SAGA backends:
> * in SAGA, the default is 100, and is printed in each module; the user
> is able to change it
> * in GRASS, the default is apparently 1, but is not shown anywhere, nor
> it can be changed; if the user leaves the default, many analyses run for
> ages.
> I would suggest to extend the behaviour of SAGA to GRASS also.
> Opinions? Should I open a ticket?
> All the best, and thanks.
> Paolo Cavallini - www.faunalia.eu
> QGIS & PostGIS courses: http://www.faunalia.eu/training.html
> Qgis-developer mailing list
