[Qgis-developer] Processing: default resolution
Paolo Cavallini cavallini at faunalia.it
Thu Apr 17 04:32:41 PDT 2014
Il 17/04/2014 13:28, Victor Olaya ha scritto:
> Not sure this is a easy fix
> In SAGA, some algorithms require that resolution, when a new raster
> layers is created and there is not a raster input (interpolation,
> rasterization...) In GRASS, that is a parameter of the region, which
> complicates things.
> If there are suggestions, I will be happy to change whatever is needed
> in the GRASS provider
I think that 100 is a more sensible default for GRASS than the current one.
Best if you could print the default in the relevant case, instead of 0,
so the user can check and eventually change it.
Thanks.
Paolo Cavallini - www.faunalia.eu
QGIS & PostGIS courses: http://www.faunalia.eu/training.html
