[Qgis-developer] FUSION integration - in slow progress
Victor Olaya
volayaf at gmail.com
Sat Apr 19 07:09:50 PDT 2014
Niccolo
Since you are working with Processing, here are a few recommendations.
- You should not create your own GUI. Unless you really want a custom
iinterface (and that's going to take you tome and it is not so easy to
do it), you should just define the semantic of the algorithm and let
Processing create the interface. Otherwise, you will not be able to
integrate it easily in the modeler, toolbox etc.
-Parameters have default values. You can use them to set the initial
value when the window is opened.
About that error when opening a csv file, can you provide more details
so I can try to fix it?
Hope this helps. Thanks!
2014-04-19 11:51 GMT+02:00 Niccolò Marchi <sciurusurbanus at hotmail.it>:
> Hello devs!
> even if on small things, I'm quite enjoying Python!
> unfortunately still too many are the questions, even silly.
> primary issue: where can I find some material dealing with Python functions?
> I'm looking for info on:
> - how to create a checkbox (code and functioning) the question dealing with
> the functioning: in which way it gives the result? (once checked, I need to
> add a particular string value to a command line)
> - trigger event that makes appear sth when checked
> secondary issues:
> - where is possible to compile the Help label? I thought to copy-paste the
> most important things directly from the manual on a html or just put the
> link to the website with the pdf manual.
> - the "open output after running algorithm" behaviour is set on ON as a
> default: is it possible to change (or delete) it in some way only for those
> tools producing a .csv? (otherwise QGIS gives an error in opening them)
> - for some parameters would be nice to have the "[optional]" text or other
> text inside the box like for "[save to temporary file]" in output: is it
> possible to add it in a quick way or should be created a class like for
> Output?
> btw, right now I added some more tools: when I'll finish everything shall I
> send a zipped folder to someone or upload the material somewhere?
> are there news on lidar developments after the code sprint in wien?
> sorry for the big disturb and thank you very much again!
> have a nice day and enjoy holidays,
> Niccolò
> Qgis-developer mailing list
