[Qgis-developer] Is minus '-' really supported in plugin names ?
Vincent Mora
vincent.mora at oslandia.com
Tue Apr 22 02:52:59 PDT 2014
I spent some time on Friday trying to upload qgis-epanet in the plugin
repository.
The doc
(http://www.qgis.org/en/docs/pyqgis_developer_cookbook/releasing.html#official-pyqgis-repository-validation)
says that
'the name of the main folder containing your plugin must contain
only contains ASCII characters (A-Z and a-z), digits and the
characters underscore (_) *and minus (-)*, also it cannot start with
a digit'
And it was also reminded to me when the Upload of the plugin failed
(plugin is broken)
I created a local plugin repo for testing the two (attached) minimal
plugins.
When installing the plugin with a minus '-' in the directory name, there
is a problem (python/pyplugin_installer/installer_data.py:620) on:
exec "import %s" % key in globals(), locals()
Plugin manager simply reports 'python said: invalid syntax' which is not
very helpful.
Note that the error only occurs when installing the plugin from
PluginManager, if you unzip under $HOME/.qgis2/python/plugins, and open
qgis, both plugins load without error.
Am I missing something obvious ?
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140422/66aff5c7/attachment.html>
Type: application/zip
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140422/66aff5c7/attachment.zip>
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140422/66aff5c7/attachment-0001.zip>
