[Qgis-developer] Plugin tags
Alessandro Pasotti
apasotti at gmail.com
Mon Apr 28 09:16:19 PDT 2014
2014-04-28 18:12 GMT+02:00 Alex Mandel <tech_dev at wildintellect.com>:
> On 04/28/2014 04:38 AM, Paolo Cavallini wrote:
> > Hi all.
> > Currently, plugins are tagged in a rather inefficient way. The list of
> > tags as displayed in the webapp (unsure whether tags used <3 times are
> > included) is:
Yes. There is a limit, IIRC is 3.
> > analysis cad cadastre calculator centroid composer database dem
> > digitizing ecology export feature field geometry google html import
> > inspire labeling land cover legend line load map metadata network
> > analysis openlayers openstreetmap osm point polygon polyline postgis
> > processing profile project python raster remote sensing routing sample
> > search selection service shape shapefile spatialite statistics style
> > time transparency vector web wkt wms
> > Some of them are very little informative, and some plugin miss what is
> > apparently their most appropriate tag.
> > I would suggest all authors to rethink their tagging strategy, and
> > converge on the most useful ones.
> > Maybe someone could suggest a list of preferred tags?
> > All the best.
> I would suggest we look for a way to allow the community to refine the
> tags on a given plugin. Upvote good tags, suggest new tags.
> Haven't checked but does the tagging system match as you type?
Sure, but the garbage comes from metadata.txt
Alessandro Pasotti
w3: www.itopen.it
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140428/9ada5fd3/attachment.html>
