[Qgis-developer] Problem with search panel in Qgis Web Client
Luca Manganelli luca76 at gmail.com
Tue Aug 5 06:40:45 PDT 2014
On Fri, Jul 25, 2014 at 9:49 AM, Luca Manganelli <luca76 at gmail.com> wrote:
> Hi,
> has anyone had problems with qgis web client and the search panel in
> the left side? With any value, the qgis FCGI module returns always an
> empty result.
> Maybe I must configure the qgis project to allow searches?
Hi, we discovered that this could be a QGIS server bug.
If you set the layer visibilty by scale (i.e. I want a layer to be
visible from 1:2.500 to below) and you do a WMS search on that layer,
the result is ALWAYS empty!
I'm going to make a ticket...
