[Qgis-developer] Problem with search panel in Qgis Web Client
Luca Manganelli
luca76 at gmail.com
Tue Aug 5 06:48:30 PDT 2014
On Tue, Aug 5, 2014 at 3:40 PM, Luca Manganelli <luca76 at gmail.com> wrote:
> On Fri, Jul 25, 2014 at 9:49 AM, Luca Manganelli <luca76 at gmail.com> wrote:
>> Hi,
>> has anyone had problems with qgis web client and the search panel in
>> the left side? With any value, the qgis FCGI module returns always an
>> empty result.
>> Maybe I must configure the qgis project to allow searches?
> Hi, we discovered that this could be a QGIS server bug.
> If you set the layer visibilty by scale (i.e. I want a layer to be
> visible from 1:2.500 to below) and you do a WMS search on that layer,
> the result is ALWAYS empty!
We have investigated futher: If you set the maximum scale 1:1, qgis
wms server returns empty resutl. If it is set to 1:0, it works.
