[Qgis-developer] Configuring OTB [+ SAGA]
Paolo Cavallini cavallini at faunalia.it
Wed Aug 6 00:55:27 PDT 2014
Il 04/08/2014 19:06, Paolo Cavallini ha scritto:
> Il 04/08/2014 18:57, Paolo Cavallini ha scritto:
>> Hi all.
>> I'm now testing the deb packaging of new (4.0) OTB. I keep on getting an error:
>> OTB execution console output
>> /usr/bin/otbApplicationLauncherCommandLine: error while loading shared libraries:
>> libOTBWrapperCommandLine.so.4.0: cannot open shared object file: No such file or
>> directory
>> What are the dir to add to config? More generally, which files should I look for?
>> I have:
>> /usr/lib/otb/libOTBWrapperCommandLine.so.4.0
>> Thanks.
> BTW, this does not work:
> http://docs.qgis.org/2.2/en/docs/user_manual/processing/3rdParty.html#orfeo-toolbox
Thanks Giovanni. I tried again on 2.4 and a clean --configpath, and I get the same error.
Problems also with saga: I had to enable 2.1, but then I get the error:
library path: /usr/lib/x86_64-linux-gnu/saga/libio_gdal.so
library name: Import/Export - GDAL/OGR
tool name : GDAL: Export Raster
author : O.Conrad (c) 2007
_____________________________________________
Load grid: /tmp/processing/e0e6e3d436cf4dea9f62b497369a9ede/VCURV.tif.sgrd...
failed
GDAL: Export Raster: could not initialize data objects
All the best.
Paolo Cavallini - www.faunalia.eu
Corsi QGIS e PostGIS: http://www.faunalia.eu/training.html
