[Qgis-developer] Building and running qgis from master
Jürgen E. Fischer
jef at norbit.de
Wed Aug 6 01:25:57 PDT 2014
Hi Jarl,
On Tue, 05. Aug 2014 at 23:12:58 +0200, Jarl Friis wrote:
> I was considering hacking a bit on qgis...
> I cloned it from github and building (on Kubuntu 14.04) the master branch.
> when running `make test` I get
> 44% tests passed, 54 tests failed out of 97
The nightly builds also run the tests:
http://dash.orfeo-toolbox.org/index.php?project=QGIS
> Is this expected?
Not the exact numbers - but that there are failing tests is no news.
> Further, when I launch qgis and exits without doing anything, it crashes with
> SEGFAULT.
Did you look at the core dump?
Jürgen
Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-31
Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
Software Engineer D-26506 Norden http://www.norbit.de
QGIS release manager (PSC) Germany IRC: jef on FreeNode
norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
Rheinstrasse 13, 26506 Norden
GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
