[Qgis-developer] Building and running qgis from master
Jarl Friis jarl at softace.dk
Wed Aug 6 04:27:45 PDT 2014
Hi Jürgen
I did spend some time o ndebugging it, however I ended up wiping my
build directory completely and
reconfiguring with
cmake ..
and then building.
Ending up with a build with much fewer errors and no SEGFAULT:
78% tests passed, 21 tests failed out of 97
However to make cmake .. pass I had to apply a patch, I'll make a pull-request.
What I believe has happend:
I have sometime during the spring configured and built qgis, then
forgot about it some time, then upgrade some packages (probably
libpython), then rebuilt qgis from updated master (even doing cmake,
make clean, make), but then somehow the build has been invalid
resulting in SEGFAULT
Anyway thanks for all your attention.
Jarl
2014-08-06 10:25 GMT+02:00 Jürgen E. <jef at norbit.de>:
> Hi Jarl,
> On Tue, 05. Aug 2014 at 23:12:58 +0200, Jarl Friis wrote:
>> I was considering hacking a bit on qgis...
>> I cloned it from github and building (on Kubuntu 14.04) the master branch.
>> when running `make test` I get
>> 44% tests passed, 54 tests failed out of 97
> The nightly builds also run the tests:
> http://dash.orfeo-toolbox.org/index.php?project=QGIS
>> Is this expected?
> Not the exact numbers - but that there are failing tests is no news.
>> Further, when I launch qgis and exits without doing anything, it crashes with
>> SEGFAULT.
> Did you look at the core dump?
> Jürgen
> Jürgen E. Fischer           norBIT GmbH             Tel. +49-4931-918175-31
> Dipl.-Inf. (FH)             Rheinstraße 13          Fax. +49-4931-918175-50
> Software Engineer           D-26506 Norden             http://www.norbit.de
> QGIS release manager (PSC)  Germany                    IRC: jef on FreeNode
> norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
> Rheinstrasse 13, 26506 Norden
> GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
> Qgis-developer mailing list
