[Qgis-developer] QGIS server ignores optional SVG symbols path
aperi2007
aperi2007 at gmail.com
Thu Aug 14 11:01:18 PDT 2014
I guess the issue was resolved.
Look at this tickets.
http://hub.qgis.org/issues/10327
and this
http://hub.qgis.org/issues/8664
You should define one or more environment variables.
for path.
We use this approach succesfully.
A.
Il 14/08/2014 17:54, Alessandro Pasotti ha scritto:
> Hi,
> I noticed that when I use SVG symbols located in an optional path as
> set in "Settings->Options->System->SVG Paths" the symbols are not
> found from QGIS server.
> The solution would be to add such information (currently missing) to
> the project file, because this is mandatory for the server to locate
> the symbols.
> Should I file a ticket?
