[Qgis-developer] QGIS server ignores optional SVG symbols path
Alessandro Pasotti
apasotti at gmail.com
Fri Aug 15 04:02:36 PDT 2014
Thank you, is this feature already available in 2.4.0 ?
2014-08-14 20:01 GMT+02:00 aperi2007 <aperi2007 at gmail.com>:
> I guess the issue was resolved.
> Look at this tickets.
> http://hub.qgis.org/issues/10327
> and this
> http://hub.qgis.org/issues/8664
> You should define one or more environment variables.
> for path.
> We use this approach succesfully.
> A.
> Il 14/08/2014 17:54, Alessandro Pasotti ha scritto:
>> Hi,
>> I noticed that when I use SVG symbols located in an optional path as
>> set in "Settings->Options->System->SVG Paths" the symbols are not
>> found from QGIS server.
>> The solution would be to add such information (currently missing) to
>> the project file, because this is mandatory for the server to locate
>> the symbols.
>> Should I file a ticket?
Alessandro Pasotti
w3: www.itopen.it
