[Qgis-developer] QGIS server ignores optional SVG symbols path
Andrea Peri aperi2007 at gmail.com
Fri Aug 15 05:41:58 PDT 2014
Of course. We are using iT just now from 2.4 qgis.server.
 Il 15/ago/2014 13:02 "Alessandro Pasotti" <apasotti at gmail.com> ha scritto:
> Thank you, is this feature already available in 2.4.0 ?
> 2014-08-14 20:01 GMT+02:00 aperi2007 <aperi2007 at gmail.com>:
> > I guess the issue was resolved.
> > Look at this tickets.
> > http://hub.qgis.org/issues/10327
> > and this
> > http://hub.qgis.org/issues/8664
> > You should define one or more environment variables.
> > for path.
> > We use this approach succesfully.
> > A.
> > Il 14/08/2014 17:54, Alessandro Pasotti ha scritto:
> >> Hi,
> >> I noticed that when I use SVG symbols located in an optional path as
> >> set in "Settings->Options->System->SVG Paths" the symbols are not
> >> found from QGIS server.
> >> The solution would be to add such information (currently missing) to
> >> the project file, because this is mandatory for the server to locate
> >> the symbols.
> >> Should I file a ticket?
> Alessandro Pasotti
> w3:   www.itopen.it
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140815/b4b3c57b/attachment.html>
