[Qgis-developer] Help on Oracle provider on Debian
Martin Dobias
wonder.sk at gmail.com
Wed Aug 20 00:15:09 PDT 2014
Hi Richard!
I have installed oracle client on my ubuntu some time ago - hopefully
it will be the same with Debian - if it works I opt for a beer ;-)
=[ client SDK ]=
- download from Oracle web (need to register):
instantclient-basiclite-linux.x64-12.1.0.1.0.zip
instantclient-sdk-linux.x64-12.1.0.1.0.zip
- unzip (e.g. somewhere to home dir)
=[ QGIS with Oracle ]=
- configure: -DWITH_ORACLE=TRUE
+ point to the library + include dir
- make sure the client library path is in LD_LIBRARY_PATH
- run QGIS with custom QT_PLUGIN_PATH=...../output/lib/qgis/plugins
(so that the OCI plugin for Qt is found)
- if running QGIS from Qt Creator, make sure to setup environment for running,
otherwise it will fail to log in with weird error messages, e.g.
ORA-12162: TNS:net service name is incorrectly specified
environment:
ORACLE_HOME=/u01/app/oracle/product/11.2.0/xe
ORACLE_SID=XE
LD_LIBRARY_PATH=/home/martin/Downloads/oracle/instantclient_12_1
(note: I run Oracle server on localhost, not sure if anything else is
necessary when run on a different machine)
Cheers
Martin
On Wed, Aug 20, 2014 at 1:48 PM, Richard Duivenvoorde
<rdmailings at duif.net> wrote:
> Hi devs,
> I want to invest some time into testing/working with the QGIS Oracle
> driver (both for QGIS-Desktop and QGIS-Server).
> First thing needed, I have: installed Oracle DB on a CentOS machine.
> But for next thing: compiling QGIS with OracleProvider on Linux/Debian
> enabled, I'll need some hints.
> Anybody experience with installing/compiling OCI on Debian, and able to
> provide a link or info about how that's done.
> I found this (old) link:
> http://ggorjan.blogspot.com/2007/04/oracle-instantclient-odbc-on-debian.html
> Which reminded me to earlier Oracle work: there is always so much to
> download, not clear what you need and what is just cruft.
> So if somebody is able to describe the minimal Oracle stuff I need to be
> able to build Oracle Driver that would be great.
> I'm happy to describe it later in a blogpost and I'll buy you a
> beer/applepie/pizza whatever whenever we meet ;-)
> Regards,
> Qgis-developer mailing list
