[Qgis-developer] Building QGIS with Microsoft Visual Studio in Windows 7
otmane yazidi alaoui yazidiotmane at gmail.com
Wed Aug 20 16:44:09 PDT 2014
hy
I change the value of:
PTYHON LIBRIRY T to C: / OSGeo4W / apps / Python27 / Lib
I have this result:
QGIS Version: 2.5.0 Master (20500)
Could not find GRASS
Found Proj: C: /OSGeo4W/lib/proj_i.lib
GEOS Found: C: /OSGeo4W/lib/geos_c.lib (3.4.2)
Found GDAL: C: /OSGeo4W/lib/gdal_i.lib (1.11.0)
Expat Found: C: /OSGeo4W/lib/libexpat.lib
Spatialindex Found: C: /OSGeo4W/lib/spatialindex_i.lib
Qwt Found: C: /OSGeo4W/lib/qwt5.lib (5.2.1)
Found Sqlite3: C: /OSGeo4W/lib/sqlite3_i.lib
Found PostgreSQL: C: /OSGeo4W/lib/libpq.lib
SpatiaLite Found: C: /OSGeo4W/lib/spatialite_i.lib
Found Qt Version: 4.7.1
Touch support disabled
Qscintilla2 Found: C: /OSGeo4W/lib/qscintilla2.lib (2.6.2)
Pedantic compile settings enabled
Found Python executable C: /OSGeo4W/bin/python.exe
Found Python Version: 2.7.4
Found Python library: C: / OSGeo4W / apps / Python27 / Lib
Found SIP Version: 4.13.1
Found PyQt4 Version: 4.8.3
Found qscintilla2 PyQt4 module: 2.6.2
GSL Found: C: /OSGeo4W/lib/gsl.lib C: /OSGeo4W/lib/cblas.lib
txt2tags not found - disabled
Ctest Binary Directory set to: C: / dev / cpp / build3 / output / bin
Configuring done
WARNING: Target "qgispython" requests linking to directory "C: / OSGeo4W /
apps / Python27 / Lib". Targets May link only to libraries. CMake is
dropping the item.
dropping the item.
dropping the item.
dropping the item.
WARNING: Target "python_module_qgis__analysis" requests linking to directory
"C: / OSGeo4W / apps / Python27 / Lib". Targets May link only to libraries.
CMake is dropping the item.
WARNING: Target "python_module_qgis__core" requests linking to directory "C:
WARNING: Target "python_module_qgis__gui" requests linking to directory "C:
WARNING: Target "python_module_qgis__networkanalysis" requests linking
to directory
to directory
to directory
to directory
Generating done
but when I open
qgis5.2 Visual studio 2008 express *
I get the following error:
1> ------ Build started: Project: qgis_core, Configuration: Debug Win32
2> ------ Build started: Project: processing-26-stageinstall, Configuration:
Debug Win32 ------
2> Performing Post-Build Event ...
1> Generating qgsexpressionparser.cpp
1> m4: can not open `Files \ GnuWin32 / share / bison ': No such file or
directory
1> m4: can not open `C: \ Program: No such file or directory
1> m4: can not open `Files \ GnuWin32 / share / bison / m4sugar / m4sugar.m4
': No such file or directory
2014-08-20 23:04 GMT+00:00 otmane yazidi alaoui <yazidiotmane at gmail.com>:
> hi
> thank you very much for your response, but you can explain more
> "Refer to ms-windows / OSGeo4W / package.cmd for the cmake settings in the
> Farming
> normal build "
> 2014-08-20 20:58 GMT+00:00 Jürgen E. <jef at norbit.de>:
> Hi,
>> On Wed, 20. Aug 2014 at 14:40:15 +0000, otmane yazidi alaoui wrote:
>> > linked by target "qgispython" in directory C:/dev/cpp/QGIS/src/python
>> > linked by target "python_module_qgis__analysis" in directory
>> > C:/dev/cpp/QGIS/python
>> > linked by target "python_module_qgis__core" in directory
>> > linked by target "python_module_qgis__gui" in directory
>> > linked by target "python_module_qgis__networkanalysis" in directory
>> Refer to ms-windows/osgeo4w/package.cmd for the cmake settings used in the
>> normal build.
>> Jürgen
>> Jürgen E. Fischer           norBIT GmbH             Tel.
>> +49-4931-918175-31
>> Dipl.-Inf. (FH)             Rheinstraße 13          Fax.
>> +49-4931-918175-50
>> Software Engineer           D-26506 Norden
>> http://www.norbit.de
>> QGIS release manager (PSC)  Germany                    IRC: jef on
>> FreeNode
>> norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
>> Rheinstrasse 13, 26506 Norden
>> GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
>        YAZIDI ALAOUI OTMANE
>            Ingénieur d'état en Géomatique
>                    Tel:+212652538743
>                    @ :yazidiotmane at gmail.com
> http://www.doyoubuzz.com/otmane-yazidi-alaoui
                   Tel:+212652538743
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140820/fb7cbb4a/attachment-0001.html>
