[Qgis-developer] Building QGIS with Microsoft Visual Studio in Windows 7
otmane yazidi alaoui
yazidiotmane at gmail.com
Thu Aug 21 07:30:06 PDT 2014
Hello everyone
I ask you, what I am doing is right or not ??
I really am stuck
thank you very much
2014-08-21 0:44 GMT+01:00 otmane yazidi alaoui <yazidiotmane at gmail.com>:
> hy
> I change the value of:
> PTYHON LIBRIRY T to C: / OSGeo4W / apps / Python27 / Lib
> I have this result:
> QGIS Version: 2.5.0 Master (20500)
> Could not find GRASS
> Found Proj: C: /OSGeo4W/lib/proj_i.lib
> GEOS Found: C: /OSGeo4W/lib/geos_c.lib (3.4.2)
> Found GDAL: C: /OSGeo4W/lib/gdal_i.lib (1.11.0)
> Expat Found: C: /OSGeo4W/lib/libexpat.lib
> Spatialindex Found: C: /OSGeo4W/lib/spatialindex_i.lib
> Qwt Found: C: /OSGeo4W/lib/qwt5.lib (5.2.1)
> Found Sqlite3: C: /OSGeo4W/lib/sqlite3_i.lib
> Found PostgreSQL: C: /OSGeo4W/lib/libpq.lib
> SpatiaLite Found: C: /OSGeo4W/lib/spatialite_i.lib
> Found Qt Version: 4.7.1
> Touch support disabled
> Qscintilla2 Found: C: /OSGeo4W/lib/qscintilla2.lib (2.6.2)
> Pedantic compile settings enabled
> Found Python executable C: /OSGeo4W/bin/python.exe
> Found Python Version: 2.7.4
> Found Python library: C: / OSGeo4W / apps / Python27 / Lib
> Found SIP Version: 4.13.1
> Found PyQt4 Version: 4.8.3
> Found qscintilla2 PyQt4 module: 2.6.2
> GSL Found: C: /OSGeo4W/lib/gsl.lib C: /OSGeo4W/lib/cblas.lib
> txt2tags not found - disabled
> Ctest Binary Directory set to: C: / dev / cpp / build3 / output / bin
> Configuring done
> WARNING: Target "qgispython" requests linking to directory "C: / OSGeo4W /
> apps / Python27 / Lib". Targets May link only to libraries. CMake is
> dropping the item.
> dropping the item.
> dropping the item.
> dropping the item.
> WARNING: Target "python_module_qgis__analysis" requests linking to directory
> "C: / OSGeo4W / apps / Python27 / Lib". Targets May link only to libraries
> . CMake is dropping the item.
> WARNING: Target "python_module_qgis__core" requests linking to directory "C:
> / OSGeo4W / apps / Python27 / Lib". Targets May link only to libraries.
> WARNING: Target "python_module_qgis__gui" requests linking to directory "C:
> WARNING: Target "python_module_qgis__networkanalysis" requests linking to directory
> Generating done
> but when I open
> qgis5.2 Visual studio 2008 express *
> I get the following error:
> 1> ------ Build started: Project: qgis_core, Configuration: Debug Win32
> 2> ------ Build started: Project: processing-26-stageinstall,
> Configuration: Debug Win32 ------
> 2> Performing Post-Build Event ...
> 1> Generating qgsexpressionparser.cpp
> 1> m4: can not open `Files \ GnuWin32 / share / bison ': No such file or
> directory
> 1> m4: can not open `C: \ Program: No such file or directory
> 1> m4: can not open `Files \ GnuWin32 / share / bison / m4sugar /
> m4sugar.m4 ': No such file or directory
> 2014-08-20 23:04 GMT+00:00 otmane yazidi alaoui <yazidiotmane at gmail.com>:
>> hi
>> thank you very much for your response, but you can explain more
>> "Refer to ms-windows / OSGeo4W / package.cmd for the cmake settings in
>> the Farming
>> normal build "
>> 2014-08-20 20:58 GMT+00:00 Jürgen E. <jef at norbit.de>:
>> Hi,
>>> On Wed, 20. Aug 2014 at 14:40:15 +0000, otmane yazidi alaoui wrote:
>>> > linked by target "qgispython" in directory C:/dev/cpp/QGIS/src/python
>>> > linked by target "python_module_qgis__analysis" in directory
>>> > C:/dev/cpp/QGIS/python
>>> > linked by target "python_module_qgis__core" in directory
>>> > linked by target "python_module_qgis__gui" in directory
>>> > linked by target "python_module_qgis__networkanalysis" in directory
>>> Refer to ms-windows/osgeo4w/package.cmd for the cmake settings used in
>>> the
>>> normal build.
>>> Jürgen
>>> Jürgen E. Fischer norBIT GmbH Tel.
>>> +49-4931-918175-31
>>> Dipl.-Inf. (FH) Rheinstraße 13 Fax.
>>> +49-4931-918175-50
>>> Software Engineer D-26506 Norden
>>> http://www.norbit.de
>>> QGIS release manager (PSC) Germany IRC: jef on
>>> FreeNode
>>> norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
>>> Rheinstrasse 13, 26506 Norden
>>> GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
>>> Qgis-developer mailing list
>>> Qgis-developer at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
>> YAZIDI ALAOUI OTMANE
>> Ingénieur d'état en Géomatique
>> Tel:+212652538743
>> @ :yazidiotmane at gmail.com
>> http://www.doyoubuzz.com/otmane-yazidi-alaoui
> Tel:+212652538743
Tel:+212652538743
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140821/a47aef7b/attachment-0001.html>
