[Qgis-developer] Struggling with iface.openFeatureForm()
Alexandre Neto
senhor.neto at gmail.com
Thu Aug 21 04:41:47 PDT 2014
Hi Bernhard,
Thanks for the link, I guess that the 2.4 problem was already identified
and corrected in master.
A bit of update on this matter. Regarding 2.2. I was doing my tests with a
dbf layer. With a postgis table is working well. So I can work with that
for now.
Still, it seems that there is something to fix in 2.5. should I open a
ticket?
Alexandre Neto
On Thu, Aug 21, 2014 at 12:37 PM, Bernhard Ströbl <bernhard.stroebl at jena.de>
wrote:
> Hi Alexandre,
> see: http://hub.qgis.org/issues/10865
> regards
> Bernhard
> Am 21.08.2014 13:23, schrieb Alexandre Neto:
>> Hello all,
>> I'm trying to finish a plugin that was initially designed for 1.8.
>> Our workflow is currently on QGIS 2.2, but we will update in the future,
>> so I'm doing some test in 2.4 and in master.
>> My goal is to open the feature form of a temporary feature in a layer,
>> and keep it's attribute values for future actions.
>> The code is something like this:
>> mc = iface.mapCanvas()
>> layer = mc.currentLayer()
>> temp_feature = QgsFeature()
>> attributes = []
>> # getting default values (for primary keys)
>> provider = layer.dataProvider()
>> for j in layer.pendingAllAttributesList():
>> if provider.defaultValue(j):
>> attributes.append(provider.defaultValue(j))
>> else:
>> attributes.append(None)
>> temp_feature.setAttributes(attributes)
>> iface.openFeatureForm(layer, temp_feature)
>> print temp_feature.attributes()
>> My "problems" are:
>> In 2.2, after I edit the feature form and press the OK button, the
>> temp_feature attributes are updated, but so is the first (already
>> commited) feature of my layer...weird.
>> In 2.4, the Feature Form always open in non editng mode, even when the
>> current layer is editable.
>> In master (2.5 1b205be), after pressing the feature form ok button, a
>> new feature is automaticly added to the attribute table, and the
>> temporary feature attributes are not updated.
>> I though it might be something to do with *updateFeatureOnly* boolean
>> value, but setting it to True does not seems to make any difference.
>> Can anyone of you QGIS developing masters throw some light into my poor
>> brain?
>> Thanks,
>> Alexandre Neto
> __________ Information from ESET Mail Security, version of virus signature
> database 10290 (20140821) __________
> The message was checked by ESET Mail Security.
> http://www.eset.com
> Qgis-developer mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140821/c7f0fd8f/attachment.html>
