[Qgis-developer] Struggling with iface.openFeatureForm()
Bernhard Ströbl
bernhard.stroebl at jena.de
Thu Aug 21 04:45:41 PDT 2014
I tried in master (1.5) after Jürgen's fix and it worked for me (PostGIS
I think)
Bernhard
Am 21.08.2014 13:41, schrieb Alexandre Neto:
> Hi Bernhard,
> Thanks for the link, I guess that the 2.4 problem was already identified
> and corrected in master.
> A bit of update on this matter. Regarding 2.2. I was doing my tests with
> a dbf layer. With a postgis table is working well. So I can work with
> that for now.
> Still, it seems that there is something to fix in 2.5. should I open a
> ticket?
> Alexandre Neto
> On Thu, Aug 21, 2014 at 12:37 PM, Bernhard Ströbl
> <bernhard.stroebl at jena.de <mailto:bernhard.stroebl at jena.de>> wrote:
> Hi Alexandre,
> see: http://hub.qgis.org/issues/__10865
> <http://hub.qgis.org/issues/10865>
> regards
> Bernhard
> Am 21.08.2014 13 <tel:21.08.2014%2013>:23, schrieb Alexandre Neto:
> Hello all,
> I'm trying to finish a plugin that was initially designed for 1.8.
> Our workflow is currently on QGIS 2.2, but we will update in the
> future,
> so I'm doing some test in 2.4 and in master.
> My goal is to open the feature form of a temporary feature in a
> layer,
> and keep it's attribute values for future actions.
> The code is something like this:
> mc = iface.mapCanvas()
> layer = mc.currentLayer()
> temp_feature = QgsFeature()
> attributes = []
> # getting default values (for primary keys)
> provider = layer.dataProvider()
> for j in layer.__pendingAllAttributesList():
> if provider.defaultValue(j):
> attributes.append(provider.__defaultValue(j))
> else:
> attributes.append(None)
> temp_feature.setAttributes(__attributes)
> iface.openFeatureForm(layer, temp_feature)
> print temp_feature.attributes()
> My "problems" are:
> In 2.2, after I edit the feature form and press the OK button, the
> temp_feature attributes are updated, but so is the first (already
> commited) feature of my layer...weird.
> In 2.4, the Feature Form always open in non editng mode, even
> when the
> current layer is editable.
> In master (2.5 1b205be), after pressing the feature form ok
> button, a
> new feature is automaticly added to the attribute table, and the
> temporary feature attributes are not updated.
> I though it might be something to do with *updateFeatureOnly*
> boolean
> value, but setting it to True does not seems to make any difference.
> Can anyone of you QGIS developing masters throw some light into
> my poor
> brain?
> Thanks,
> Alexandre Neto
> _________________________________________________
> __________ Information from ESET Mail Security, version of virus
> signature database 10290 (20140821) __________
> The message was checked by ESET Mail Security.
> http://www.eset.com
> Qgis-developer mailing list
> Qgis-developer at lists.osgeo.org <mailto:Qgis-developer at lists.osgeo.org>
> http://lists.osgeo.org/__mailman/listinfo/qgis-__developer
> <http://lists.osgeo.org/mailman/listinfo/qgis-developer>
__________ Information from ESET Mail Security, version of virus signature database 10290 (20140821) __________
http://www.eset.com
