[Qgis-developer] Different gdalinfo Results
    M Lewis
    Martin.Lewis at euro.ngc.com
    Fri Aug 22 01:00:32 PDT 2014
I have already raised this on the GDAL-Dev forum (a lot of help but no
conclusive answer) so sorry for cross posting but this might make more sense
here.
I use QGIS for verification of an application that uses pure GDAL (built by
myself)
I have had some problems with a particular MrSID file where 'gdalinfo' run
from QGIS gives a different (although correct result) compared to 'pure'
gdal.
Both versions when running 'gdalinfo --version' give 'GDAL 1.11.0, released
2014/04/16'
I am building GDAL using the latest MrSID DSDK 9.0.0.3864.
The results of the gdal_info are as follows, the differences highlighted in
bold:
Output from QGIS gdal info
Driver: MrSID/Multi-resolution Seamless Image Database (MrSID)
Files: E:\Stuff\Maps\georgiaville_se.sid
Size is 5189, 6945
Coordinate System is:
*PROJCS["NAD83 / Rhode Island",*
    GEOGCS["NAD83",
        DATUM["North_American_Datum_1983",
            SPHEROID["GRS 1980",6378137,298.2572221010002,
                AUTHORITY["EPSG","7019"]],
            AUTHORITY["EPSG","6269"]],
        PRIMEM["Greenwich",0],
        UNIT["degree",0.0174532925199433],
        AUTHORITY["EPSG","4269"]],
    PROJECTION["Transverse_Mercator"],
    PARAMETER["latitude_of_origin",41.08333333333334],
    PARAMETER["central_meridian",-71.5],
    PARAMETER["scale_factor",0.99999375],
*    PARAMETER["false_easting",328083.3333333333],*
    PARAMETER["false_northing",0],
*    UNIT["US survey foot",0.3048006096012192, *
        AUTHORITY["EPSG","9003"]]]
Origin = (311060.109583333310000,311248.359216666660000)
Pixel Size = (3.280833333333334,-3.280833333333334)
Metadata:
  GEOTIFF_CHAR__GTModelTypeGeoKey=ModelTypeProjected
  GEOTIFF_CHAR__GTRasterTypeGeoKey=RasterPixelIsArea
  GEOTIFF_CHAR__ProjectedCSTypeGeoKey=PCS_NAD83_Rhode_Island
  GEOTIFF_CHAR__ProjLinearUnitsGeoKey=Linear_Foot_US_Survey
  GEOTIFF_NUM__1024__GTModelTypeGeoKey=1
  GEOTIFF_NUM__1025__GTRasterTypeGeoKey=1
  GEOTIFF_NUM__1026__GTCitationGeoKey=IMAGINE GeoTIFF Support
Copyright 1991 - 2001 by ERDAS, Inc. All Rights Reserved
@(#)$RCSfile: egtf.c $ $Revision: 1.10.1.6 $ $Date: 2003/10/17 16:36:51EDT $
Projection Name = State Plane
Units = feet
GeoTIFF Units = feet
  GEOTIFF_NUM__3072__ProjectedCSTypeGeoKey=32130
  GEOTIFF_NUM__3073__PCSCitationGeoKey=IMAGINE GeoTIFF Support
State Plane Zone -3800
NAD = 83
  GEOTIFF_NUM__3076__ProjLinearUnitsGeoKey=9003
  IMAGE__COMPRESSION_BLOCK_SIZE=512
  IMAGE__COMPRESSION_GAMMA=2.000000
  IMAGE__COMPRESSION_NLEV=7
  IMAGE__COMPRESSION_VERSION=2,0,0
  IMAGE__COMPRESSION_WEIGHT=2.000000
  IMAGE__CREATION_DATE=Mon Feb 07 13:53:36 2005
  IMAGE__INPUT_FILE_SIZE=108169367.000000
  IMAGE__INPUT_FORMAT=GeoTIFF
  IMAGE__INPUT_NAME=E:\Aerials\USDA\TIFS\4107104_se.tif
  IMAGE__TARGET_COMPRESSION_RATIO=25.000000
  VERSION=MG2
Image Structure Metadata:
  INTERLEAVE=PIXEL
Corner Coordinates:
*Upper Left  (  311060.110,  311248.359) ( 71d33'45.24"W, 41d56'15.01"N)
Lower Left  (  311060.110,  288462.972) ( 71d33'45.02"W, 41d52'29.91"N)
Upper Right (  328084.354,  311248.359) ( 71d29'59.99"W, 41d56'15.07"N)
Lower Right (  328084.354,  288462.972) ( 71d29'59.99"W, 41d52'29.97"N)
Center      (  319572.232,  299855.665) ( 71d31'52.56"W, 41d54'22.51"N)*
Band 1 Block=1024x128 Type=Byte, ColorInterp=Red
  Minimum=23.000, Maximum=253.000, Mean=76.340, StdDev=27.247
  Overviews: 2595x3473, 1298x1737, 649x869, 325x435, 163x218, 82x109, 41x55
Band 2 Block=1024x128 Type=Byte, ColorInterp=Green
  Minimum=36.000, Maximum=254.000, Mean=92.388, StdDev=23.622
Band 3 Block=1024x128 Type=Byte, ColorInterp=Blue
  Minimum=46.000, Maximum=254.000, Mean=82.477, StdDev=21.573
Output from 'pure gdal' gdalinfo
Files: C:\Stuff\MrSid\Georgiaville_SE\georgiaville_se.sid
Size is 5189, 6945
*PROJCS["State Plane",*
    GEOGCS["NAD83",
*    PARAMETER["false_easting",1076386.736111111],*
*    UNIT["feet",0.3048006096012192]]*
Metadata:
Units = feet
NAD = 83
  VERSION=MG2
  INTERLEAVE=PIXEL
Corner Coordinates:
*Upper Left  (  311060.110,  311248.359) ( 74d18'40.33"W, 41d54'11.14"N)
Lower Left  (  311060.110,  288462.972) ( 74d18'30.47"W, 41d50'26.31"N)
Upper Right (  328084.354,  311248.359) ( 74d14'55.46"W, 41d54'16.59"N)
Lower Right (  328084.354,  288462.972) ( 74d14'45.82"W, 41d50'31.75"N)
Center      (  319572.232,  299855.665) ( 74d16'43.02"W, 41d52'21.46"N)*
The problem appears to be in the 'false_easting'.
What I would like to know is, what QGIS does differently?
The answer from GDAL-Dev was that there was a bug in gdal but how can this
be if QGIS reports a different answer using the same gdal version?
What can I do to make my gdal do the same as the gdal built into QGIS? Is it
a tweaked data file?
This is causing me major issues as I need to be able to display these MrSID
files in the application that we have and at the moment they are about 145
miles out!
Hope someone can help.
Thanks
Martin
View this message in context: http://osgeo-org.1560.x6.nabble.com/Different-gdalinfo-Results-tp5157771.html
Sent from the Quantum GIS - Developer mailing list archive at Nabble.com.
