[Qgis-developer] Identify results form vs feature form
Nathan Woodrow
madmanwoo at gmail.com
Mon Aug 25 15:49:22 PDT 2014
The reason I moved the option is because it wasn't really a "option" in the
first place. Something like that doesn't belong in the options dialog as it
can be changed more then once during a session, and if you are having to
visit the options dialog for that then it's in the wrong place. Anything
found in Settings -> Options should not have to be changed a lot, set once
and forget. The old method was also inconsistent, sometimes you might not
want the feature form to open for a single feature but you got it
regardless unless you did the Settings -> Options dance to change it for a
single use case.
I agree that getting the identify results dock back is not the best,
however moving the settings back to Options is not the solution. I am
thinking a Open Result Pane button next to the identity map tool button.
The recommend workflow is to leave the identify result dock open, put it in
a tab if you need, and control the settings for identity from there. They
will persist between sessions just like the last settings. The identify
result dock will always show the current results regardless of if the
feature form is shown or not. This is to make it more consistent from a
users point of view as the tool always does the same action regardless,
showing the results. Opening the feature form is a bonus on top of the
standard function not in replace of.
It was never about hiding the options. In fact quite the opposite. Moving
them to the dock now give you more live control on a need by need basis
rather then Settings -> Options...dance if you need to change it for a
session.
Regards,
Nathan
On Tue, Aug 26, 2014 at 3:22 AM, Andre Joost <andre+joost at nurfuerspam.de>
wrote:
> Am 25.08.2014 17:34, schrieb Jürgen E. Fischer:
> Hi André,
>> On Mon, 25. Aug 2014 at 17:26:02 +0200, Andre Joost wrote:
>>> "Open feature form, if a single feature is identified"
>> I can not find that option in QGIS 2.4 and QGIS dev anymore.
>> It's in the identify dialog now.
> There is an option to show the feature form and a checkbox "Auto open
> form" , yes. It's not easy to understand that checking that will open the
> feature form for single features.
> If I set the checkbox, I have no chance to get the identify result form
> back if my layers contain only single features.
> The old option method looked somewhat more logical to me. Any chance to
> get it back? It would not harm anybody, and the docs are correct again.
> It is still in the lastest docs
>>> http://docs.qgis.org/testing/en/docs/user_manual/introduction/qgis_
>>> configuration.html#options>
>> Sounds like a bug.
> If you click the "Help button" of the identify form, it also tells me
> about the old options.
>> Am I missing something well-hidden?
>> IMHO if the objective was to hide it, Nathan miseably failed at it ;)
> Perhaps we should give him a second chance ;-)
> Greetings,
> André Joost
> Qgis-developer mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140826/f5ff758d/attachment-0001.html>
