[Qgis-developer] Processing causes major slowness at QGIS startup
Luca Manganelli
luca76 at gmail.com
Tue Aug 26 23:36:27 PDT 2014
On Wed, Aug 27, 2014 at 7:43 AM, Martin Dobias <wonder.sk at gmail.com> wrote:
> Actually since the adoption of metadata.txt for plugin metadata it is
> not necessary for QGIS to load all python plugins on start up. I have
> a suspicion that it is the plugin installer component which tries to
> load them while QGIS is being started (just to check whether they load
> correctly). Such check is IMHO not necessary and its removal would
> make the loading time shorter.
+1 for me :-) fixing this problem could be a big improvement in startup time!
